![]() | Home > Maintenance & Modifications > Fitting a Canvas Hood to a 2016 90 Pick Up o 110 DCPU |
Trentster Member Since: 23 Feb 2016 Location: London Posts: 68 ![]() ![]() |
Can anyone tell me when fitting a canvas hood to a 90 Pick Up or a 110 DCPU is the galvanised metal water gully expected to be diverted onto the back of the truck cab?
![]() Click image to enlarge ![]() Click image to enlarge |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Have a scan over this
![]() http://www.defender2.net/forum/topic53805.html |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I don't think it's wrong as it fits around the hood sticks at the base. Mine is a cab fit, so I have a frame around the window...
You need to drill the cab and rivet it on, top tip, use lots of silicone sealer. QRZ 2e0vpf |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
To confirm
Yep tht is right..the canvas clips into the small holes along that galvanised bit with the clips that should of come with it Good luck Nice vehicles |
Just make sure you don’t channel the water towards that Persian rug, you wouldn’t want to ruin it.
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Hi guys and thank you for all you advice.
Just a bit nervous about riverting into the bodywork but that seems how it fits. Once I've done it I might post the Persian Rug on the For Sale & Wanted section in case Grenadier fancies bidding on it! |
Do you ever plan on removing it again?
I run my DCPU without a hood so removed the channel, welded up the holes left by rivets and had the cab repainted I wonder whether double sided 3M would do the job? If you are keeping the spare wheel behind the cab, tightening the wheel against the channel will keep it largely in place |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
When I removed the gutter strip and window surround frame from my DCPU to fit an Ifor Williams canpoy, I simply fitted a machine screw with a nylon insert stiff nut together with a dab of sealant through each of the former rivet holes. They don't leak, and I can refit the removed parts any time I wish using the same screws/
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
The channel also keeps the tension on the canvas, if it wasn't secured properly the canvas will shrink considerably. Don't ask me how I know ![]() |
I don't think the hood will be removed - certainly not while I own it.
One of the reasons why I wanted to put the hood on is because without it the truck just fills with leaves and water unless it is parked pointing up hill so the water just flows out of the tailgate. |
With the hood in place the gap between it & the rear of the cab will be the place where all those leaves gather....
And as others have said use plenty of sealant around the very poorly fitting outer edges. |
For those who don't want a full hood, I can highly recommend the Exmoor Trim canvas tonneau which I have fitted. Very well thought out bit of kit, sturdy, clean and keeps the bay watertight. Rolls back easily and fastens with clip ties if you want to put something in higher than the tub line. Excellent
![]() ![]() Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
![]() Click image to enlarge Zoom in behind cab |
Foxy
What's the make of that cover? |
