![]() | Home > Technical > Refitting a double cab hood to back of tub. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2328 ![]() ![]() ![]() |
There's a 'retaining strip' that clamps the hood onto the drain channel using dzus fasteners
https://www.landroverworkshop.com/diagrams...xing_52698 |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 260 ![]() ![]() ![]() |
Hank,
Thanks for the quick reply. I don't recall those at all, but will google:- I wonder would it be different for an 03 model? Cheers |
Don't know, but the exploded diagram looks the same for TD5 and Puma
Seems as though you're missing these http://www.exmoortrim.co.uk/our-models/def...annel.html http://www.exmoortrim.co.uk/our-models/def...-hood.html |
Thanks Hank again for the links and time. Very helpful. Definitely missing those parts. I'll search further for an image of how it all fits together.
My hood isn't fitted either but will get some photos of how it goes back together tomorrow
So as we established the 'Drain Channel' is pop riveted to the rear of the cab and the 'Retaining Strip' slots into the canvas hood and then fastens the hood to the drain channel with 1/4 turn Dzus fasteners.
The orientation of the Retaining Strip is shown in the following link, you will also notice it has four slots and four holes. https://www.landroverworkshop.com/diagrams...xing_52698 Drain channel shown on the left, Retaining strip shown on the right... ![]() Click image to enlarge The retaining strip is basically a length of angle aluminium and slots into a 'channel' sewn in to the front of the hood. The four slots I previously mentioned in the retaining strip locate the retaining strip in position around stitching in the hood. This will make more sense when you look at it than it does in writing... From outside the hood (the retaining strip has been rotated almost 180 degrees for the photo) ![]() Click image to enlarge From inside ![]() Click image to enlarge The following two photos shown the Retaining Strip fitted to the Drain Channel with the 1/4 turn Dzus fasteners. So the canvas 'channel' sewn into the hood would be vertical inside the Drain Channel ![]() Click image to enlarge ![]() Click image to enlarge This is really difficult to explain in writing but if you have parts 24, 27 and 4no. 26 & 29 from the landroverworkshop link then that's all you need Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Hank,
That's brilliant. I can see and understand now what exactly I'm missing. Pricing it up, it also doesn't look too expensive to finish the set up (though some other related parts are ridiculously priced for what they are). Thank you for all your time. Cheers Rob |
No probs. The only thing left to fathom is where your original bits went!
