Home > Technical > Electric window |
Good news, glad you found the information you needed and sorted it! If you go through life with your head in the sand....all people will see is an ar5e!!
31st Jul 2015 8:42am |
ECH241 Member Since: 02 Feb 2016 Location: Wiltshire Posts: 23 |
Hi woundered if any one could help??... My drivers side electric window won't work I have checked the fuse and it was blown so swapped it for another (new 20amp) and this also blew?? Any help would be great thanks
4th Feb 2016 10:36pm |
I'd be looking at the bunch of wires that go from the door pillar to the door itself. These are prone to breaking inside the rubber sheath, it's highly likely that the wire/s have broken and earthing out causing the fuse to blow.
4th Feb 2016 10:48pm |
Ok brilliant I will check in the morning and let you no....might b asking for a bit more help yet thanks
4th Feb 2016 10:51pm |
Spot on jwl it was just like u said cheers
5th Feb 2016 8:36pm |
Mike T Member Since: 21 Apr 2016 Location: Randburg Gauteng Posts: 1 |
Hey Guys, This thread was a lifesaver. Right drivers electric window stopped working...checked fuses and relay, all good. Then stripped the door down and found the green cable sheared off. Re-soldered, extended and all back to normal in under an hour. Thanks Boys
21st Apr 2016 11:47am |
edalelr Member Since: 15 Dec 2016 Location: Derbyshire Posts: 4 |
I have a slight variation on this problem... on both sides the electric windows have become increasingly difficult to open, requiring a lot of pressing of the switches to get anything to happen. This started on the drivers side, which got progressively worse, then started on the passenger side. Now almost impossible to open either side. The weird thing is that the whole time, even now, they close absolutely perfectly.
Could this still be a switch problem or the usual issue with broken wires at the door pillar? Or is it more likely to be something to do with the actual winding mechanisms? I would have thought the latter if it wasn't happening on both sides. Any advice much appreciated! Thanks! |
15th Dec 2016 11:02pm |
mactheknife Member Since: 08 Jul 2016 Location: Somerset Posts: 51 |
Just used this thread to find the problem with my drivers window. Hottest day of the year, defender boiling inside after being in the sun all day and an hours drive home with no ac or opening window!.
Checked the fuses, swapped the switches. Still no fix. Quick Google and I arrived here. 2 mins later I find a broken wire in the door loom! Thanks for all the responses on here, well done. |
2nd May 2017 11:03pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
I have this issue now checked wires in rubber tube between door and Pilar as best I could the seem to be intact. Where are the fuses located as I'll start from there I guess. Can you get to and swap the switches from the stereo gap btw?
22nd Jan 2018 10:26am |
In trying to shift the rubber sleeve back I found a broken red wire . Struggling to get the sleeve to pull back though and really don't want to cut it.
23rd Jan 2018 10:30am |
managed to repair this by feeding through some new higher spec wire through the conduit and making the new joins . Electric window works again, for now at least anyway
29th Jan 2018 10:56am |
russfish Member Since: 27 Nov 2017 Location: Farnham Posts: 5 |
This was a great thread, thank you chaps.
After testing the fuses, swapping the switches (as passenger side window worked fine) then looked at the rubber conduit between car and door, eventually found the culprits, both wires blue and red were broken half wa along inside the conduit. As pointed out earlier in this thread, this wire does seem to be particularly stiffer, therefore less flexible and I imagine prone to breaking. I threaded some rubber encased outdoor wires through the original conduit and crimped the joins. All the older wire is now either in the pillar or in the door, so won’t be moved resulting in breakage. I guess I’ll just wait until I have to do it again on the passenger door side! Thank you again guys - really useful. |
8th Feb 2018 7:03pm |
that man Member Since: 17 Dec 2016 Location: Cheshire Posts: 83 |
Brilliant boys right first time broken raed wire in the flexi rubber fixed sorted BRILL Many thanks --- that man
3rd Mar 2018 11:06pm |
Leeroy Member Since: 01 Aug 2015 Location: East Yorkshire Posts: 261 |
Thanks guys mine gave up today in this
Click image to enlarge weather |
17th Mar 2018 7:27pm |
