Home > Technical > First "issue" |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2012 |
Anything to do with the CD player?
25th Jan 2018 12:08am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Yes CD player fault? Or has it had an electronic ariel fitted? 2002 90 Td5 Station Wagon
25th Jan 2018 12:09am |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
maybe im not alone when it comes to the radio surround not staying in place and popping out at the bottom
25th Jan 2018 1:19pm |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
Some people wire ignition feeds from the radio so it's likely that it could be a relay that another owner added that is being powered from the radio. Possible Sub that has been removed?
25th Jan 2018 1:37pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Had that same head unit in my old D2 & it used to 'chatter' when it was cold & I tried to play a CD. Radio worked fine & once things had warmed up inside the CD player would work fine too. Would imagine that in a Defender the symptoms would be more frequent!
25th Jan 2018 1:46pm |
davybull Member Since: 10 Dec 2017 Location: Wigan Posts: 54 |
No Electric Ariel Grafty.
It happens when I switch it on without a CD in it. I'll maybe get a chance to make some radio removal pins tomorrow and have a look. Time is short!! |
25th Jan 2018 5:05pm |
No you are not alone! Going to try and sort that at the same time just for the moment but may get one of the MUD fascia plates soon. |
25th Jan 2018 5:18pm |
If it doesn't make the noise with a CD in, but it does make a noise without a CD, then surely it must be the internals of the CD player that are at fault...?
...and a couple of thin screw drivers in the holes will probably get the radio out of the facia without to much trouble. |
25th Jan 2018 6:17pm |
Nutter Member Since: 15 Sep 2014 Location: Birchington Posts: 24 |
Does it make a noise with the engine off it could be a bad ariel earth.
25th Jan 2018 7:51pm |
