Page 1065 of 1393 <123 ... 106410651066 ... 139113921393>
mk1collector
Post #680398 21st Jan 2018 2:12pm
Slideywindows
Roy5695 wrote:
Took the wuffers out. No better thing to do, Landy, Mans best friend and your finest Cornish sea air Thumbs Up
Talking of irresponsible photos, Roy what on earth are you doing posting pictures of lovely Cornwall on here?
Don't you realise that it has been perpetually grey in Essex for what seems like forever?
That it rained all day long from leaden skies yesterday in Essex?
That it is grey, cold and snowing all day in Essex today?
Do you really want the whole of Essex to up-sticks and move to Cornwall?
Think man, think! Shocked
Wink
Post #680405 21st Jan 2018 2:50pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Sorry regards the pub I didn't go in just past it ,we did in fact go in the Red lion after the match Laughing
Post #680429 21st Jan 2018 4:20pm
Expensive day today, we got stuck... Expensive because we are now need something to go laning in!
The wind was biting and it was freezing the rain on the mirrors...
We had a good day out though..
 QRZ 2e0vpf
Post #680435 21st Jan 2018 4:35pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
You must be keen to actually get out and take a photo in that weather. Almost as daft as someone who washes theirs in similar weather Laughing All in the name of keeping the forum alive Very Happy
Post #680439 21st Jan 2018 4:41pm
Terryt
Went to the beach
Post #680443 21st Jan 2018 4:46pm
AJC
Where did you go to find all that snow? I didn't think there was any south of Preston!
TD5 needed for laning then!
Post #680673 22nd Jan 2018 8:46am
Thumbs Up
this was around Flash between Leek and Buxton.
It's handy as the cafe have a webcam !!
http://www.flashbarstores.co.uk/ QRZ 2e0vpf
Post #680730 22nd Jan 2018 2:40pm
Drove mine today every day chores, heading back after just coming off a roundabout I had quite a vibration.
Seemed worse at lower speeds around 1st 2nd 3rd gear, especially when coming to a halt.
Thought maybe I had a flat tyre, seemed like the passenger front area but on inspection I didn't.
Couldn't investigate further tonight driving back in the dark and wet, it's seemed to come and go not too noticeable.
Bit of a rumble at times, again around the 3rd gear 2k revs range.
It appears to be the left side area, hubs didn't seem warm or hot and no obvious signs of leaks.
Need to check tyre pressures though, and wondering if maybe I've lost a balancing weight.
I was wondering the above, drive shaft or wheel bearings, possibly prop UJ's.
Anyone got any ideas? Obviously I'm going to hope and check the easiest options first.
Especially tyre pressures, any loss of balancing weights and wheel bearings.
There seemed no difference in acceleration, under braking, steering or anything like that.
Which is why I'm thinking rotational balance. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #680803 22nd Jan 2018 7:58pm
grafty99
Quite possibly a UJ. Wheel imbalances usually show themselves at slightly higher speeds Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #680806 22nd Jan 2018 8:06pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Steve,
Might be worth checking your wheelnuts. I have had similar issues when they haven't been nipped up enough. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #680807 22nd Jan 2018 8:08pm
Will check tomorrow, but no good tonight. Thumbs Up
How would I go about checking the UJ's? Bear in mind I'm not a mechanic or engineer.
It seemed to come and go, I got home okay without any problems and seemed to improve but at times there was a bit of a rumble.
On the whole, it didn't seem too bad but something is or has been a miss and I had came back though the lateness so obviously very wet, mucky and rough as most are at the moment.
Definitely will check the wheel nuts as well whilst at it, braking, accelerating, steering and actual control seems fine no lurching or anything like that at all. ____\We|Will|Win/___
Post #680814 22nd Jan 2018 8:21pm
grafty99
You'll be looking for a less extreme version of this.....
1990 Vogue SE
Post #680821 22nd Jan 2018 8:36pm
JWL
I've been having a little trouble with my el-cheapo amplified radio aerial recently so with an hour spare I decided to have a look. When I took it off the wing the metal contact on the base had been reacting with the aluminium and the centre of the coax cable had snapped. I then had the bright idea to put it up on the roofrack so I made a bracket that attached to the spotlight brackets, extended the wires and turned the radio on. Success, even tucked behind my garage it could pick up all the radio stations and even better was that it worked as it should when driving about this afternoon doing the college pickups Thumbs Up
Post #680831 22nd Jan 2018 8:48pm
Grafty - Thank-you. Thumbs Up ____\We|Will|Win/___
Post #680842 22nd Jan 2018 9:03pm
