![]() | Home > Technical > Immobiliser problems. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I would start by changing the batteries on the fobs and making sure they're synced to the vehicle by repeatedly pressing lock and unlock 2002 90 Td5 Station Wagon
Guy. Member Since: 16 Jan 2018 Location: Staffordshire Posts: 9 ![]() |
Thanks but as I said, I have replaced the batteries in both fobs.
I have put a pair of what I though were new batteries in my fobs. Turned out they were out of date and flatter than the ones they replaced. It's worth checking the date on the packet 2002 90 Td5 Station Wagon
And synced them!
I did check voltage and both new ones were outputting 3.3 volts which is fine.
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
Guy Phone Chris at CSK 01992 217830 he's just found out how to fix this, mine is going in on Wednesday .This is a 2012 year only issue.
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 371 ![]() ![]() |
Will this solution help me?
http://www.defender2.net/forum/topic58522.html It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 ![]() ![]() ![]() |
I have a 63 doing exactly the same
Thank you very much. I'll ring Chris first thing. Watch this space!!
If you have the same symptoms as above phone CSK as he is the only person I know of who has fixed this problem and it's not the fobs.I would go in to detail but I'm no mechanic and don't really know the why's or how's. |
There always some one who breaks the mould ![]() |
any update on this one Guy did you ring Chris ?
I've spoken to Chris at CSK. Symptoms I have are the same as Chris has with a Defender he has just sorted. It's a known fault with the immobiliser control module which is situated within the dash cluster. Land Rover are aware of the fault and originally issued a service bulletin to dealers but no recall. Repair is only possible by replacing the control module and associated wiring. According to Chris, who has just done it successfully, it's not a nice job! I'll keep you posted on progress.
I wonder if you can change the dash cluster from another to test this
