Home > Technical > Immobiliser problems.
Page 2 of 2 <12
Guy.
That has to be worth a try but you would have to programme it to the vehicle after fitting.
Post #679213 17th Jan 2018 12:32pm
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
is it not the 10as behind the cluster ?
Post #679214 17th Jan 2018 12:34pm
Guy.
You've lost me. What's the 10as?
Post #679245 17th Jan 2018 2:22pm
Guy.
OK. 10as is the alarm module.
Post #679253 17th Jan 2018 2:38pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Hi It is the 10AS alarm module ,but all so to fit it you need different loom which means removing the complete dash,I only know this because Chris is doing my 90 at this very moment .I will let you all know when I pick it .
Post #679265 17th Jan 2018 3:21pm
legin
Well my 90's all fixed and I'm out about enjoying it again,so Chris's fix has worked .Any one who has this problem should book in with CSK who can do it in a day if all the parts can be pre ordered before hand.
Post #680098 20th Jan 2018 8:51am
russfish
England 2010 Defender 110 Puma 2.4 DCPU Indus Silver
A slight reverse on the problem...
Last weekend some idiots decided to try and nick my DC10. Ripped out the near side indicator to cross the wires and create a short, then tried to go in through the offside top vent and near side headlamp bezel (like blimbug).
Thankfully they either got disturbed or gave up, but my issue though is that the alarm and immobiliser are not working. (They we’re working fine beforehand). The central locking all works on the fob, but no flashing indicator lights. I’ve replaced a number of fuses that were blown, replaced the reconnection on the horn etc that the scumbags disconnected, rewired and replaced the side repeater they tore out, but don’t know if I’m missing anything else?
Just ordered a gps tracker DefenderDefender with remote cut off, but want to ensure my alarm/immob are all fully working first.
Any help would be most appreciated, anyone any ideas?
Post #685550 10th Feb 2018 4:19pm
Page 2 of 2 <12
