![]() | Home > Tdi > Can defender 300tdi engine go into a discovery??? |
There is no real difference between them. Between the Def and Disco 200tdi there was a lot of difference.
The only issue I can think of is that the engine and gearbox mounts if the 300 is going in to a 200 or v8 disco. Not sure about the bulkhead and gearbox tunnel though. |
jackdefender1991 Member Since: 13 May 2017 Location: Salisbury Posts: 28 ![]() ![]() ![]() |
Thanks for that, I was getting confused with the differences in the 200tdi
Cheers |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8461 ![]() ![]() ![]() |
300 def to 300 disco yes it will go, use the original 300 disco intercooler and pipes believ the outlet anlges are slightly different but may be wrong.
300def to 200disco - yes but Gbox different and engine mounts. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Is the gearbox selector set not different between the two? I’m sure you have to swap them over to get it to fit. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Gbox selector is different but believe he's retaining the disco gbox from post Cheers
annette Member Since: 24 Nov 2017 Location: Tilarán, Costa Rica Posts: 68 ![]() ![]() |
the engine is the same. Gearbox is more of a problem you have to swap the top. better get a disco one and save the 110 box, the selector quarters are impossible to get now and worth money. Fixing Land Rovers in rural Guanacaste |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 ![]() ![]() ![]() |
Yeh the discovery R380 has the long inputsgaft and bellhousing, , this moves the gearshift quadrant etc,,back[ beside centre conssel] , as the defender shift is forward [ on the floor]
