Home > Tdi > Can defender 300tdi engine go into a discovery???
jackdefender1991
United Kingdom 1991 Defender 110 200 Tdi DCPU Aintree Green
Hi all,
I have a quick question that I am sure many of you will know the answer to.
I have a 300tdi engine and gearbox removed from my old 110 ,
Can this go into an early disco belonging to my friend?
Any help appreciated. Thanks
Post #678225 13th Jan 2018 8:02pm
geobloke
There is no real difference between them. Between the Def and Disco 200tdi there was a lot of difference.
The only issue I can think of is that the engine and gearbox mounts if the 300 is going in to a 200 or v8 disco. Not sure about the bulkhead and gearbox tunnel though.
Post #678227 13th Jan 2018 8:28pm
jackdefender1991
Thanks for that, I was getting confused with the differences in the 200tdi
Post #678230 13th Jan 2018 8:33pm
jst
300 def to 300 disco yes it will go, use the original 300 disco intercooler and pipes believ the outlet anlges are slightly different but may be wrong.
300def to 200disco - yes but Gbox different and engine mounts. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #678248 13th Jan 2018 10:16pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Is the gearbox selector set not different between the two? I’m sure you have to swap them over to get it to fit. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #678254 13th Jan 2018 10:34pm
jst
Gbox selector is different but believe he's retaining the disco gbox from post Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #678310 14th Jan 2018 9:56am
annette
Costa Rica
Re: Can defender 300tdi engine go into a discovery???
jackdefender1991 wrote:
Hi all,
the engine is the same.
Gearbox is more of a problem you have to swap the top.
better get a disco one and save the 110 box, the selector quarters are impossible to get now and worth money. Fixing Land Rovers in rural Guanacaste
Post #681390 24th Jan 2018 6:42pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Yeh the discovery R380 has the long inputsgaft and bellhousing, , this moves the gearshift quadrant etc,,back[ beside centre conssel] , as the defender shift is forward [ on the floor]
Post #681709 25th Jan 2018 10:40pm
