![]() | Home > Technical > Is it me? |
you need separate the green plastic from metal inner part also this part below is stopping you removing it from the dash
![]() Click image to enlarge ![]() Last edited by dorsetsmith on 9th Jan 2018 2:43pm. Edited 1 time in total |
capnjapseye Member Since: 21 Feb 2015 Location: Cornwall Posts: 223 ![]() ![]() ![]() |
Can’t see how the green placky bit separates from the metal bit? 2015 90 Hard Top
1998 90 300Tdi - chuffed to have another one 2013 Freelander 2 - for posher trips to the shop 1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it 2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit 2010 90 Hard Top - now sold Ex mil 90 - now sold |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18027 ![]() ![]() ![]() |
It's held on with poxy little clips that break when you try to remove it, thus ensuring that it can never be refitted.
Who needs a light in the socket anyway? |
Can’t seem to separate the green plastic & the metal components, seems virtually impossible to get the lighter socket out of the dash 2015 90 Hard Top
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
If it was me I'd very carefully cut it out, bin it and replace.
I'll have the same issue myself soon, don't think it's really an option to remove and replace damage free. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
No I’ve broken 2
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1311 ![]() ![]() |
This is depressing news, I've got a replacement lighter unit being delivered tomorrow.
Maybe the new removable bit will work in the existing socket, so I won't have to replace that. ![]() |
LR want you to buy a complete centre dash see for £260 or what ever they are now. Plus an arm and a leg of course.
![]() They used to be around £120 as well. I'm guessing the Genguine lighter is £26 or so each as well. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I’m trying to remove it to transfer it to my new DD dash but now thinking I might just install a double USB charging socket in the new dash instead 2015 90 Hard Top
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 ![]() ![]() ![]() |
I replaced mine with one of these:
http://www.sailsmarine.com/ItemDetail.aspx...rtight_Cap Much more useful and a perfect fit. |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I have managed in the past to remove the lighter with out damage but only on the ones as in photo two by the following means. Remove fuse for lighter, put a loop of wire over each of the prongs as can be seen in the photo and pulling gently on each wire in turn, the wires need to be crossed to pull them inwards. Once it starts to move out you may have to jjjjiggle it a bit and use either a trim removal tool of small screwdriver to ease it out. The metal part should ease out leaving the green outer in place , you will need nimble fingers to remove the bulb holder from the green outer which can the be slid out gently. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Interesting stuff, I'm on it again dreckly
I have used the Blue Sea twin USB charger unit before on a boat refit I was doing and was impressed 2015 90 Hard Top 1998 90 300Tdi - chuffed to have another one 2013 Freelander 2 - for posher trips to the shop 1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it 2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit 2010 90 Hard Top - now sold Ex mil 90 - now sold |
