Home > Technical > Is it me?
capnjapseye
United Kingdom 2016 Defender 90 Puma 2.2 HT Santorini Black
Is it me?
How the hell does the fag lighter socket come out of the Puma dash? 2015 90 Hard Top
1998 90 300Tdi - chuffed to have another one
2013 Freelander 2 - for posher trips to the shop
1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it
2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit
2010 90 Hard Top - now sold
Ex mil 90 - now sold
Post #677192 9th Jan 2018 2:27pm
dorsetsmith
you need separate the green plastic from metal inner part also this part below is stopping you removing it from the dash
Post #677195 9th Jan 2018 2:36pm
capnjapseye
Can’t see how the green placky bit separates from the metal bit? 2015 90 Hard Top
Post #677196 9th Jan 2018 2:41pm
It's held on with poxy little clips that break when you try to remove it, thus ensuring that it can never be refitted.
Who needs a light in the socket anyway?
Post #677228 9th Jan 2018 5:22pm
capnjapseye
Can’t seem to separate the green plastic & the metal components, seems virtually impossible to get the lighter socket out of the dash 2015 90 Hard Top
Post #677290 9th Jan 2018 9:07pm
If it was me I'd very carefully cut it out, bin it and replace.
I'll have the same issue myself soon, don't think it's really an option to remove and replace damage free. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #677296 9th Jan 2018 9:18pm
ibexman
No I’ve broken 2 Whistle
Post #677305 9th Jan 2018 9:41pm
Slideywindows
This is depressing news, I've got a replacement lighter unit being delivered tomorrow.
Maybe the new removable bit will work in the existing socket, so I won't have to replace that. Neutral
Post #677309 9th Jan 2018 9:46pm
LR want you to buy a complete centre dash see for £260 or what ever they are now. Plus an arm and a leg of course. Rolling Eyes
They used to be around £120 as well.
I'm guessing the Genguine lighter is £26 or so each as well. Rolling Eyes ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #677314 9th Jan 2018 9:57pm
capnjapseye
I’m trying to remove it to transfer it to my new DD dash but now thinking I might just install a double USB charging socket in the new dash instead 2015 90 Hard Top
Post #677377 10th Jan 2018 10:03am
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
I replaced mine with one of these:
http://www.sailsmarine.com/ItemDetail.aspx...rtight_Cap
Much more useful and a perfect fit.
Post #677379 10th Jan 2018 10:11am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I have managed in the past to remove the lighter with out damage but only on the ones as in photo two by the following means.
Remove fuse for lighter, put a loop of wire over each of the prongs as can be seen in the photo and pulling gently on each wire in turn, the wires need to be crossed to pull them inwards. Once it starts to move out you may have to jjjjiggle it a bit and use either a trim removal tool of small screwdriver to ease it out. The metal part should ease out leaving the green outer in place , you will need nimble fingers to remove the bulb holder from the green outer which can the be slid out gently. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #677391 10th Jan 2018 11:20am
capnjapseye
Interesting stuff, I'm on it again dreckly
I have used the Blue Sea twin USB charger unit before on a boat refit I was doing and was impressed 2015 90 Hard Top
Post #677392 10th Jan 2018 11:27am
