![]() | Home > Technical > "oil" trickle down the clutch pedal |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
i would supect the clutch master cylinder is leaking 2004 TD5 Defender 90 xs station wagon
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Common fault... 100% master cylinder... a
gambit Member Since: 26 Mar 2011 Location: Sussex Posts: 79 ![]() |
Thanks for the diagnosis, so now going to look up and see if this is a DIY job, or too difficult
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6048 ![]() ![]() |
Do the master cylinder and the slave at the same time
![]() ![]() One has gone the other will soon fail. Andy |
Having had a look in the workshop manual, looks like there are not too many steps, although some could be fiddly.
Is there much in the different makes, TRW Vs Land Rover for example? Thanks Andrew |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
I had a drip from my pedal a few weeks back seemed a little oily, though I had been offroad and wondered if it was muddy water getting through. Anyway it dried up and hasn't come back and the clutch fluid level seems ok.
I did have to top up the clutch fluid a few months back, but not since. Can you get an intermittent leak? Steve ![]() Discovery 3 HSE BMW 330i Coupe |
Hmmm - I guess I can understand why, but the workshop manual makes it seem a very straightforward and easy job to change....
Found this though http://landytown.myfastforum.org/Defender_...t4893.html Not quite so straightforward as the manual made out, but still a DIY task I guess - albeit a long one. |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
Could be worth thinking about this,
http://www.td5alive.com/new_products.php Im thinking of getting it to stop the problem i have in my left ear, the Mrs moaning about the bloody clutch being heavy in traffic. Dont know how much or when its ready, but if its a good price got to be a worth while investment. |
Clutch master cylinder was a right mess.
Took all afternoon, but changed now - and thanks to a trip to Halfords and picking up an Eezibleed kit, no air in the system either. That gadget certainly made short work of any fluid problems I had after changing the cylinder ![]() |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
I have the same telltale trickle of clutch fluid down the clutch pedal I have just noticed today. The pedal seems to have a bit of 'slack' at the top of the travel as well as a result. I haven't checked the fluid reservoir to see if it's low. Do I have a bit of time before it gives out completely (can I drive it for the next couple of days?), or is it a case of getting it into the garage ASAP? It's only done 25k, but I suppose it's an age-related thing as well to some extent? (It's a 2005).
Cheers, Tris. |
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 ![]() ![]() ![]() |
Just changed mine on my 06 TD5, not a hard job, more fiddely than anything else. Top tip is to take the bonnet off for greater access. Life is not a rehearsal!
Def 90td5 CSW xs 2006 |
Mine has only 28k, as long as you keep an eye on the fluid level it will be ok for a few days (maybe longer) but I would look to get it fixed as soon as you can, a new cylinder is only about £45 for an OEM one, or about £70 for a genuine one...........0r £15 for a ![]() Its an easy enough job to do........I managed it and Im a NOVICE diy mechanic ![]() Def 90td5 CSW xs 2006 |
Cheers Alan. Sounds like both of ours have gone at pretty similar times, so that's reassuring (in a weird Land Rover way!) I don't think I will do it myself, although I have a workshop manual, I don't really know what I'm doing and worry about stuffing it up! I've got a good local independent, so will take it to him. Should be able to get it booked in for the end of the week. Thanks for the advice and offer of assistance. ![]() |
