Home > My Defender > Grafty's Td5 90
Page 58 of 124 <123 ... 575859 ... 122123124>
grafty99
Yeah it does a bit, this is the only picture to hand with it visible
 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #675950 5th Jan 2018 12:27am
993porky
United Kingdom 2002 Defender 90 Td5 HT Baltic Blue
Cheers grafty Thumbs Up
So once you have design done is it just like ordinary printer in terms of clicking print on laptop and provided every thing is plugged in thats it.
What is the plastic like when finished is it tough or flexy or brittle,forgive my ignorance just all new to me this 3d printing but something im keen to have a go at Thumbs Up
Is your printer a top end one or a beginners one,as im looking for advice on what type to buy
Any advice appreciated and a big help thanks
Post #675951 5th Jan 2018 12:28am
grafty99
So when you have completed your design, you save it as a .STL file. This is imported into a slicing software which converts the design into something the printer can use (called gCode). This is then transferred to the printer via USB cable or an SDcard.
Then it is essentially press print and leave it to go.
In the setup of the gCode to some extent determines the strength of the finished item. A fast low quality print won't be as strong as a slower high quality one. Also the density of infill has a bearing. A correctly setup printer and a good design will produce objects that near injection moulded strength Thumbs Up
My printer is on the upper end of budget printers I would say. £300 roughly and I had it printing within an hour of opening the box. (No prior experience) I say budget because 3D printers can run into thousands of pounds Shocked
The less you spend, the more construction work is needed. Mine is an all metal construction which gives good stability for accurate prints. Many of the sub £200 printers are plastic, which will flex more.
The beauty of the lower cost printers is that once up and running you can print upgrade parts to improve them Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #675952 5th Jan 2018 12:41am
993porky
Thank you Grafty
Dont mean to be a pest asking,but if you dont ask you dont learn thats my thinking anyway Bow down
Your advice is a big help Thumbs Up
Thank you
Post #675953 5th Jan 2018 12:53am
grafty99
Not at all, that's exactly what a forum is for! Glad to help Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #675958 5th Jan 2018 1:13am
grafty99
Today has not been a good day Sad Started this morning at 9 for a full service, literally anything that moves has been given attention (as I do every service @5000 miles).
Changed the coolant (as I do every 2 years) and guess what happens?
As I went to replace the top hose bleed screw I pushed the thread into the hose Evil or Very Mad so whip the top hose and thermostat off, do you think I can find it?!? So I now have a fully serviced immobile defender with some kind of threaded brass or plastic floating around in there to try and sort on a Sunday morning Big Cry 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #676404 6th Jan 2018 7:10pm
grafty99
Well today I very quickly realised that I wasn't going to get anywhere with the defender. I found the offending thread and other bits if broken plastic in the thermostat housing luckily and as all the local places that might have had a new top hose were closed, I decided to go back in the warm.
A while later I ended up with a new design for my air intake vent. It's on the printer now but this is the picture of the CAD drawing Thumbs Up
1990 Vogue SE
Post #676656 7th Jan 2018 7:08pm
Procta
looking good that grafty Thumbs Up You will save your self a small fortune there! If it turns out well you can even sell those on too Very Happy Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #676674 7th Jan 2018 7:44pm
grafty99
Haha maybe! Your vents will be in the post first thing tomorrow Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #676676 7th Jan 2018 7:45pm
Procta
Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #676803 8th Jan 2018 7:01am
grafty99
Off for a weekend away today, a quick clean before departure and quickly fitted genuine front mud flaps. I used to have them but removed them for some reason and lost them Embarassed so anyway £64 ( Shocked ) later here they are in all their flappyness Laughing
1990 Vogue SE
Post #678044 12th Jan 2018 11:38pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Fantastic pictures! Bow down Thumbs Up
Your truck really has come on a long way when you compare it to the picture in your first post on this thread. Pretty much unrecognisable! Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #678046 12th Jan 2018 11:44pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Looks great grafty, enjoy the weekend Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #678051 13th Jan 2018 12:01am
grafty99
Thank you Bow down Embarassed
They're only taken with my phone Shocked I've got some better ones on Instagram Thumbs Up
In reality it's been a slow evolution but yes, side by side they're very different. I got it when I was 16, 9 years ago Shocked 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #678052 13th Jan 2018 12:02am
grafty99
Some more pictures here Thumbs Up
www.instagram.com/george_grafton 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #678057 13th Jan 2018 12:39am
