Home > Puma (Tdci) > Drain
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Drain
Friends, can someone tell me the place of drainage of condensate water from the air conditioning, the room floods me !!!!!!!
Post #676345 6th Jan 2018 2:03pm
ericvv
While lying under the truck (or better have the truck up on a post) you should reach with your hand into the cramped space of the transmission tunnel in the middle above the gearbox just after the bell housing. You should find a rubber bung there which can be blocked. Squeeze it open again and you should get a shower of airco evaporation water. The rubber bung is similar to the one on the bottom of the heater intake box. Good luck.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #676352 6th Jan 2018 2:40pm
Fernando
Thank you very much Eric, very precise your indication, I already solve it. !!! Thumbs Up
But what an uncomfortable place!
Post #681000 23rd Jan 2018 10:23am
