![]() | Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
The one on the right is in the correct orientation to go into the dash with the nozzle attatched on the underside
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Ended up going on a new years eve ride on my motorbike today so some update pics of the vents tomorrow hopefully
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11074 ![]() ![]() |
Got the lower vent nozzles assembled and installed today, I adjusted the design of the nozzle because I thought the previous version aimed the air too low, well unfortunately I think this aims the air too high, right at your face which isn't really ideal. I think version 2 will need some vertical air adjustment control.
Anyway here are the prototypes assembled installed ![]() ![]() Click image to enlarge ![]() Click image to enlarge As you can see, the base needs to have a larger lip to cover the profile in the dash to finish it better. But not bad for a first prototype ![]() ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 521 ![]() ![]() ![]() |
Looking excellent!
Normally I would ask what material you are printing in for this sort of application but I don't think there's any risk of a defender heater melting/deforming plastic! ![]() Well not on Tdis and Td5s at least, pumas have the opposite problem - it's like having a blowtorch on your leg!! Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Tell me about it, when my puma was up to temperature you couldn't hold your hand in front of the top air vents on full heat and fan
![]() To be fair though a properly adjusted tdi/5 heater is pretty effective. I have to turn mine down once the inside is up to temperature ![]() Printed it standard PLA ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Matt you have an e-mail
Just received thanks!
![]() ![]() '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5367 ![]() ![]() |
looking good there grafty
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Thanks Procta
![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Another little mod I've done today is upgrade the springs in my wiper arms. The springs are out of the spare range rovers wiper arms. They are a direct swap and certainly improve the screen pressure!
A few photos for comparison ![]() ![]() Click image to enlarge Spring pressure before - box lifts all but 10mm of the blade off the screen ![]() Click image to enlarge Spring pressure after - box only manages to lift half of the blade so quite an improvement I think ![]() ![]() Click image to enlarge Also as you can see in the first picture, the actual pressed steel part of the range rover arm is thicker to prevent flex. I plan to shorten these arms for the defender to take advantage of the thicker material at some point ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1457 ![]() ![]() ![]() |
By properly adjusted do you mean the cable on top of the heater box? I have noticed my green one is warmer than new blue one. I have checked the arm is on max adjustment with the Cable , but it's still only slightly warm ![]() ![]() Makes a change for no sarcasm ![]() ![]() |
New year new you Jim?
![]() Yes the top cable needs to be properly adjusted to make the foam inside the heater box seal properly from unheated air. Have you checked that the thermostat is good? the gauge may say normal but the blue one could be running cold. Blue after all is a colder colour ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
