Home > Maintenance & Modifications > Aux battery choice
simons17
Aux battery choice
Evening all
Looking to replace my failing yellow top aux battery. What are you guys using want to keep it in the battery compartment in a 300 tdi 90
Simon
Post #674488 30th Dec 2017 7:47pm
mikeh501
2x blue tops for me.
Post #674494 30th Dec 2017 8:10pm
Cupboard
I used a pair of flooded Vartas, but I believe the earlier Defenders had a slightly different size of battery box?
Post #674556 30th Dec 2017 10:50pm
simons17
Thanks guys will look into both. For the blue tops how long does the aux battery last if camping etc. I run a fridge and lighting off mine.
Cheers Simon
Post #674765 31st Dec 2017 5:57pm
jst
i have used:
2 x Numax CVX27 to really good effect in 3 vehicles -. one as camping based, other two as winch vehicles.https://www.mdsbattery.co.uk/shop/productp...oupID=8800
Also used Enduroline equivalent.
One set of batts is still going strong 9 years on.
One set i swapped out last year for two PC15000 but the Numax will be going back in.
other winch vehicle i sold last year, chap was out today in it, still running same batts, been in there 5years. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #674816 31st Dec 2017 8:35pm
simons17
Thanks JST, this sounds great my red top only lasted 18 months and my yellow top 2 years so far from impressed with them. So will have a look at these
Regards
Simon
Post #674900 1st Jan 2018 9:58am
walfy
jst wrote:
i have used:
Are the NUMAX the same size as the ODYSSEY? Fitting 2 X PC1500 in. That is some going. I think I have 2X 1200(?) and that was a squeeze in the PUMA. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #674906 1st Jan 2018 10:36am
mikeh501
blue tops are 55ah iirc. not huge, but decent as a pair. get a solar panel too?
Post #674976 1st Jan 2018 4:22pm
jst
The pc1500 to in easy in a d44 holder. The numax are a really tight squeeze in there Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #675057 1st Jan 2018 9:28pm
I'm just about to replace the 2x optima red tops in my 110. they still work but lose charge after about 5 or 6 days of non use.
They've been in various LR's of mine for the last 18 years, so have lasted pretty well!
they're just wired in parallel at the moment. In a previous 90 they were powered by 2x alternators with a link switch if I needed an extra boost (so both charged separately)
Running either a husky or 8274 winch. They've been worked hard, and I've gone for the same to replace them.
Post #675177 2nd Jan 2018 4:24pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Have now pulled the dead Oddyssey batteries out of both of mine and replaced one set with Numax batteries and the other with Enduroline batteries at a fraction of the cost of the Odysseys.
For the competition/winch motor I went for two batteries the same as they are permanently connected in parallel, for the overland motor which has an isolator between the two batteries I went for two different ones, one normal car battery and the other a leisure battery.
Fitting the first two was a bit of a chew as the Numax 086 batteries were slightly too long for the D44 holder so I had to modify the holder. Armed with that knowledge, the second set I ordered after checking the dimensions first against the D44 carrier whilst getting the biggest capacity I could fit. I did have to replace the D44 bolts with threaded rod though as the batteries were too tall for the original bolts to fit.
Got them through Tayna batteries online where they list all the dimensions and they deliver at a good price. http://www.yorkshireoffroadclub.net/
Post #675193 2nd Jan 2018 5:25pm
Glass Duracell battery in mine now, ECP have some good deals on them from time to time
Post #675271 2nd Jan 2018 9:55pm
pannawonica
Australia
I have two odyssey PC1500 in mine, yes they where a bit of a price! However they are coming up four years old, I only got two years out of the original! Big Cry
Post #675300 3rd Jan 2018 2:31am
Mo Murphy
I use Numax batteries at present, good solid long lived batteries. Optima are not the batteries they once were and I'm wary if the price/hype surrounding Odyssey batteries.
Bang for buck you can't beat Numax.
50 Shades of Pennine Grey
Post #675347 3rd Jan 2018 11:06am
TJ101
Again like above,, 2 x PC1500 with Blue sea system to charge/maintain etc ,,
Just now have my doubt one the aux Oddyssey being able to hold its charge ? recon about 4 years old now, and not done a lot
Next is to decide 1 x new Pc1500 or bin and 2 x new Numax California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #675420 3rd Jan 2018 3:35pm
