Home > Maintenance & Modifications > Aux battery choice
Page 2 of 2 <12
isacs
Sorry to ask...novice question but why 2 batteries?
Post #675431 3rd Jan 2018 5:07pm
walfy
If you run a winch, it's a good idea to have a second battery. Or if you travel on extended trips having a fridge is good. Plus it allows the accessory to flatten the 2nd batt if needed and still leaving your main batt to start the veh. 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #675434 3rd Jan 2018 5:16pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
TJ101 wrote:
Again like above,, 2 x PC1500 with Blue sea system to charge/maintain etc ,,
Just now have my doubt one the aux Oddyssey being able to hold its charge ? recon about 4 years old now, and not done a lot
Next is to decide 1 x new Pc1500 or bin and 2 x new Numax
Funny enough I have the same problem. Two PC15000's with the starter/main battery not being able to hold its charge for long(1 week max.). Thankfully the aux. one steps in when needed! Tried reconditioning it with a ctek but no joy.
The genuine LR one that the Defender Came with is over 7 years old and fitted to a Fordson Major is still showing maximum hold!
Post #675435 3rd Jan 2018 5:18pm
walfy
[/quote]Are the NUMAX the same size as the ODYSSEY? Fitting 2 X PC1500 in. That is some going. I think I have 2X 1200(?) and that was a squeeze in the PUMA.[/quote]
Just been and checked the 110. Felt it strange that I had PC1200's and everyone else running 1500. I have 2 X 1500, which was a bit of relief 110 D250 SE HT
110 USW SOLD
Post #675440 3rd Jan 2018 5:28pm
TJ101
I have another new PC1500 that was acquired Very Happy sat in the box, will do some checks on the aux one, and see how it goes, have a feeling it about had it ! Just don't think they are not what they use to be !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #675441 3rd Jan 2018 5:30pm
walfy
I agree, not what they used to be. Hasn't Philon ditched all of his in favour of something else now on his truck? 110 D250 SE HT
110 USW SOLD
Post #675444 3rd Jan 2018 5:33pm
TJ101
Correct,, and they were VERY expensive ones PC2250 ?? about £400 a time !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #675453 3rd Jan 2018 6:15pm
Hendrix
England 2013 Defender 110 Puma 2.2 USW Santorini Black
Used 2 yellow tops and red top in my old 300 setup, mainly because I could fit all 3 in seat box. At the start would run fridge for 3 days but wasn't long before performance dropped off. Currently have one Bison auxiliary and solar panel, worked well on Balkans tour last year but did get sun most days.
Post #676092 5th Jan 2018 4:13pm
msb
United Kingdom 2004 Defender 90 Td5 PU Coniston Green
I swapped my two PC1500s out after they stopped holding charge when about 4 years old.
I put 2 Exide Maxxima 900DC (New Part Number EP450) in. They fit in the same space (D44 holder) and have been faultless.
I wad recommended them by a mate who has had them in his challenge truck for many years without issue.
Post #676163 5th Jan 2018 8:02pm
simons17
As most have said the second battery is for the accessories winch fridge etc. You need to have an isolation i.e. Split charge between the two batteries this allows aux battery to drain down without draining the starting car battery.
Post #676240 5th Jan 2018 11:54pm
ibexman
I had 2 maximas only lasted just over 4years ,I think there’s a lot of hype re optima ,Odessy exide ect I have
2 OEM LFD 90s 1 has been in there over 10 years Whistle
Post #676245 6th Jan 2018 12:48am
Page 2 of 2 <12
