Home > Series Land Rovers > And away we go again! S3 V8 project...
Page 9 of 13 <123 ... 8910 111213>
familymad
Top job Thumbs Up 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #673814 28th Dec 2017 5:08pm
Romadog
Ian that sounds lovely - subtlety always the best Thumbs Up
Other half at the other end of the sofa managed to turn to me when I played the last video and smiled............will play it more often !! Rolling with laughter
Post #673874 28th Dec 2017 7:50pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Rolling with laughter Thumbs Up
Nice one! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #673877 28th Dec 2017 8:02pm
dorsetsmith
Bow down Bow down Bow down
Post #673886 28th Dec 2017 8:18pm
Pickles
Sounds pretty good to me, & it'll sound even better when "the pedal's to the metal", under load!
Pickles.
Post #673936 28th Dec 2017 10:25pm
L110CDL
That sound was heaven Ian, i had to listen to it 3-4 times then my youngest daughter had to listen to it a couple of times, she just loved it Wink Very Happy Very Happy Clayton.
Keeper.
Post #673953 28th Dec 2017 10:50pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Hi Ian,
How's your S111 progressing?
Happy New Year
Andy Thumbs Up Working towards Carry on camping!
Post #674671 31st Dec 2017 2:06pm
ian series 1
Hi Andy
Happy new year to you too Thumbs Up
I've spent the best part of my Christmas holiday working on the series 3!
I've had all sorts of problems from a non functional dash (poor earth in hazard switch)
This took a long time to find the culprit!
Amazing how one earth in a switch can cause no end of grief,
To number 5 cylinder with a stripped spark plug thread.... Big Cry Big Cry Big Cry
All good now though, which is a relief!
I managed to get a reverse spark plug thread tap, which was an amazingly simple but clever tool,
Other than that it would have been a head off job.
All things going back together nicely,
Just 2 outer wings, and doors to paint, and cab roof.
Fitted some sound deadening to the bulkhead, and footwells,
Decided to carpet the whole cab like a Defender.
I'm going to set myself a goal and aim for an MOT at end of Jan! Whistle
 80" 80" 86" 88" 90"
Post #674734 31st Dec 2017 5:38pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Coming along nicely. I see you have some (K&N ?) filters fitted. Did you run it with the normal air filter/box previously and if so are the K&N,s much noisier? The reason I ask is I was considering these rather than the huge air filter arrangement on my V8 90.
Post #674739 31st Dec 2017 6:12pm
gcc130
Hi Ian,
Have you considered a Wright Off a Road/ Exmoor matting system?
Quite expensive I know but I've used them in several defenders and have been impressed with both sound and heat deadening, also hard wearing and easy to clean.
Andrew
Post #674742 31st Dec 2017 6:17pm
Romadog
I found one of those reverse tools too......didnt know they even existed.....but glad also that they do Bow down Thumbs Up Thumbs Up
K&N's allow you to hear those SU's sucking the mixture Very Happy Very Happy Thumbs Up
Post #674749 31st Dec 2017 6:25pm
Carpet is a brave choice Shocked
It looks really nice Ian, kudos to you, fingers crossed for a good month of spannering and a trouble free MOT, don't do what I did and run out of fuel on the way Laughing
Happy New Year QRZ 2e0vpf
Post #674756 31st Dec 2017 6:45pm
ian series 1
Believe it or not, I have just brought an original air box assembly for it!
I'm not a big fan of the aftermarket air filters, they were only EBay specials, I'm not sure how they would cope with muddy water?
I think the induction noise on a run would get a bit tedious, it's going to be bad enough listening to the noise at the back! plus I've read on the V8 forum that there should be a slight restriction with the SUs to run better?
When you look at the size of air intake on a standard set up, it makes you wonder?
Andrew, good to hear from you.
(See your doing well with the CLR appearances!) Laughing Bow down
I did look at the Exmoor set up, but I've chopped the bulkhead around quite a bit, meaning I would have to drastically take the knife to it! Thumbs Up
Romadog,
Glad some clever sod thought of that!
I've had a stripped thread in one before many years ago, and was always waiting for it to blow the plug out Rolling Eyes
I'm not sure if it was like that before, or when I changed the plugs it picked up taking the old plug out?
Luckily it was just the first few turns that were damaged. Thumbs Up 80" 80" 86" 88" 90"
Post #674758 31st Dec 2017 6:46pm
ian series 1
Cheers Greeni.
I've got a Gunson colour tune at work, it's running way too rich at the moment,
So I will get that sorted next weekend.
I put 25ltrs of petrol in on Christmas Eve,
Gauge is now showing empty, with the fuel light on.
I've only had it on tickover not ever been out of first!... Rolling with laughter 80" 80" 86" 88" 90"
Post #674761 31st Dec 2017 6:51pm
Andy80
Great progress Ian,
Work for a rest on Tuesday!! Rolling with laughter
Ali heads stripping is always a nemesis I guess a little anti-seize and correct torque will help but I have still stripped threads.
Post #674769 31st Dec 2017 7:08pm
