![]() | Home > Tdi > Fuel: white smoke |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
I had white misty smoke coming from mine at start up, more noticeable on a cold morning. wasn't really using water, turned out to be a hairline crack in head
![]() as the head warmed the crack must have closed enough not to notice. bungud a new shiny head from turners on and cured it! ![]() my youtube channel |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 521 ![]() ![]() ![]() |
Hold your hand over the exhaust for a few seconds, you'll soon be able to tell if it smells overwhelmingly of diesel or if it's a sweeter smell - ie anti freeze so leaking coolant.
Hopefully it's not a cracked head ![]() ![]() '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Its definitely diesel! 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5357 ![]() ![]() |
I recon its the glow plugs, kit. Sometimes if you use cheep ones, they don't last all that long. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Bad glow plugs might make it smoke more at first startup but I don't
think wouldn't make a difference after that. I start my 300tdi without giving it heat anyway, glowplugs aren't really necessary on these engines. Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
you will be surprised, what bad glow plugs can do. I had a very similar problem with my Dturbo 306. With the glow plugs not heating the diesel properly. With the temperatures been as low as they have been is going to throw up weak parts.
I had to change my 306 HDI battery, as it wouldn't start when the temperature dropped right off. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8407 ![]() ![]() ![]() |
if the timing was out you could have excess fuel in the cylinder prior to combustion stroke, more apparent when cold. Cheers
Thought i'd give an update on this, JST was on the money, the timing was out
![]() 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 ![]() ![]() ![]() |
Ah, who ever fitted the timing belt, didnt slacken the 3 bolts on the fuel pump pully when tensioning the belt, ?
Yep, I had it done the same time I had my front axle replaced
glad its resolved. Cheers
