Home > Off Topic > My RRC project
Page 13 of 53 <123 ... 121314 ... 515253>
Procta
coming on very strong there grafty Thumbs Up as soon as the running gear is in, you practically half way there. Shame you cannot get the boxes sent away to be rebuilt and upgraded, but then again I don't know what budget or time scale you are working to.
How common is a TD5 conversion into a RRC? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #672582 22nd Dec 2017 12:39am
grafty99
To be honest I think the best upgrade you can do to the gearbox is an improved cooler. The standard one is pretty pants. Time scale is the main thing. I aim to have it on the road for my birthday in March and I can't be waiting for the gearbox to be rebuilt. Especially as I can do it myself Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #672583 22nd Dec 2017 12:44am
grafty99
I have seen a couple of Td5 conversions. It makes sense as in many ways it's similar to a Td5 disco. There is certainly room. I'll probably make the second one into a Td5 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672584 22nd Dec 2017 12:46am
Procta
how easy is it to do a conversion in one of these then? I can see it not been a simple plug in play. If I was going to tackle an engine conversion again, id be wanting to see one in real life and wanting a good sorce of info, I had a bad experience with my last engine conversion sadly. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #672586 22nd Dec 2017 12:56am
grafty99
Td5 is easy really. Just need engine loom, ECU, 10AS and fuel pump. If going simpler than that you can fiddle the ECU to not look for the alarm module but you may as well activate the alarm and have the security.
Engine mounts would need welding but really pretty simple Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672588 22nd Dec 2017 1:02am
grafty99
You could even put a Td5 speed transducer in the transfer box and then a speedohealer to double the output to the ECU and then have factory cruise control Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672589 22nd Dec 2017 1:03am
Procta
are the main looms the same across the board then grafty? I can see the engine mounts been the easiest part. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #672594 22nd Dec 2017 2:01am
grafty99
The engine loom is Td5 specific. It is basically all of the sensors and injectors to ecu. Essentially everything from the red plug on a Td5 ECU Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672609 22nd Dec 2017 9:19am
Procta
when I did my engine conversion grafty, I had to send away the vvc engine loom off to be converted over so it could plug into the metro main loom, Laugh is a lot of people were tight lipped on what wires to move over etc, a couple of years later, I was talking to a MG metro cup driver at the time who had done the same conversion, and he said it was only 6 wires to swop around! He said if Id known you were going to do yours, id have told you what wires to move over, save you the 70 quid!
Is it the same for these with the range rover/ defender looms? Or is the RRCs the same loom as the disco? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #673226 25th Dec 2017 12:19am
grafty99
The looms are totally different. However all you need is the engine loom to ECU then supply the engine and ECU with the correct power and ground. This would be independent of the main vehicle loom Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #673228 25th Dec 2017 12:42am
Procta
sounds more easier, than the vvc conversion I did Thumbs Up depending on what year the metro was, you had to have the loom converted to such. Which to me is still questionable to this day. Which was down to the alarm system, which was known as the 5AS ( 10 AS to defender lads)
you know what the most easiest thing would be, is to wire in the full works from the donor car, which is what some of the mg metro cup lads did, ( they ran the rover 25 engines in with the latest ecu system)
To me id just replace the full loom for a disco TD5 loom into a range rover classic. but I don't know about land/ range rover systems. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #673241 25th Dec 2017 3:42am
grafty99
Small update on the range rover. The autobox is now fitted. Just waiting for someone to become available to help me manoeuvre the transfer box into place Thumbs Up
1990 Vogue SE
Post #673913 28th Dec 2017 9:55pm
L110CDL
Looking good there grafty Thumbs Up at the moment i'm free tomorrow afternoon to come and help you Whistle Clayton.
Keeper.
Post #673917 28th Dec 2017 10:02pm
Procta
That's if he isn't to busy playing with his new toy to take you up on the offer clayton Whistle Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #673923 28th Dec 2017 10:07pm
L110CDL
It will soon pass and he will get back to the job in hand Procta Laughing Clayton.
Keeper.
Post #673947 28th Dec 2017 10:36pm
