Home > Wheels & Tyres > New boots and wheels
Djcla
Before
After
STT Pros in 265/75/r16 , writing is white but they got some washable blue paint on them for some reason.
Loving my new aggressive tyres its the look I wanted and wheels look sweet imo of course.. only slight issue is the rub on lock and it's like turning a barge to avoid rubbing so thinking of getting 30mm spacers. I didn't want spacers but have little choice .
Post #672847 23rd Dec 2017 5:10pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Very nice. Just wind the lock stops out a bit to fix the rub. Thumbs Up Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #672852 23rd Dec 2017 5:37pm
Djcla
Hmm yes one has snapped off Sad, I'll have a look at the other side
Post #672854 23rd Dec 2017 5:49pm
dorsetsmith
12mm x 50mm 8.8 bolt and haft nut
STEERING
ADJUSTMENT
STEERING LOCK STOPS
Service repair no - 57.65.03
Check
1. Measure clearance between tyre wall and radius
arm at full lock. This must be not less than 20
mm.
Adjust
2. Loosen stop bolt locknut.
3. Turn stop bolt as required.
4. Tighten locknut.
5. Check clearance between tyre wall and radius
arm on each lock.
NOTE: Alternatively lock stop adjustment
may be carried out using following
procedure.
Check
1. Measure stop bolt protrusion �A�. Refer to table
for correct setting.
Adjust
4. Tighten locknut.
5. Check wheel position at full lock.
LOCK STOP SETTINGS
Tyre & wheel size - alloys
Make
Size
Setting
BF Goodrich Mud Terrain
265
59,7 mm
Goodyear GT+4
235
55,7 mm
Michelin M+S 4x4
235
54,2 mm
Tyre & wheel size - steel
Make
Size
Setting
Goodyear
205
52,2 mm
Michelin
205
52,2 mm
Avon
7.50
56 mm
Michelin
7.50
56 mm
Goodyear
7.50
56 mm
Post #672855 23rd Dec 2017 5:52pm
Djcla
I'll try find a guide on adjusting them and have go at the other side
Post #672856 23rd Dec 2017 5:53pm
Sulisuli
Follow the info Dorsetsmith has posted and your sorted Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #672879 23rd Dec 2017 7:28pm
Djcla
Nice thank you , I'll have a play with the one that's intact if it works, I'll drill out the broken one
Post #672881 23rd Dec 2017 7:32pm
Sulisuli
Spray plenty of WD40 on the unbroken one first and let it soak in to make it easier. Wheels and tyres look fab Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #672884 23rd Dec 2017 7:35pm
Brendlynch
Jersey 2005 Defender 110 Td5 XS CSW Cairns Blue
Hi
How is the noise level compared to the old set?
Post #672946 24th Dec 2017 12:24am
Djcla
I'm driving the noisest car known to man so tyre noise isn't really something I've noticed Smile. In all honesty they are so much nicer on the tarmac driving wise compared to the old Avon's and noise I can't say I've noticed. Perhaps when u get to 60+ but I rarely sit at that speed. I had someone else in car with me and they didn't notice either. Tbh you are not buying these tyres if you are doing a 1000's of miles a month but I don't have an issue with noise or even notice it over the radio.
Post #672953 24th Dec 2017 12:36am
Leeroy
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
dorsetsmith Bow down
Very useful for future changes
Thanks Leeroy
Post #672988 24th Dec 2017 10:02am
Djcla
Trying to measure the stop bolt protrusion today, not exactly an easy place to get a accurate measurement. It's around 50mm at the moment , but I could do with working out a way of accurately measuring it before adjusting. I haven't quite wrapped my head around how they work yet either , will wait for a dry day before I have a go at them.
Post #673097 24th Dec 2017 5:44pm
Djcla
Adjusted one bolt but 50mm bolts are too short to get the required measurement as per the above table .
Post #673611 27th Dec 2017 4:42pm
dorsetsmith
that's odd from LR work shop manual i haven't try this set up with 265 75 16
Post #673619 27th Dec 2017 5:03pm
Djcla
Yup, obviously u can get the right length but there is no thread other side to fit a nut
Post #673623 27th Dec 2017 5:16pm
