![]() | Home > Maintenance & Modifications > Fitting a side fuel tank to 110 |
| lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764
Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
Old thread but to update,, The remaining fuel in the aux tank, below the outlet to main is 13 lts for the Front runner aux tank California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8365
surprised me when you said that the other day too, now a way to get that out without an exposed Balance pipe..... or drilling into main tank below the chassis!. Cheers
Actually, its not that exposed, as the forward mount bracket covers the balance pipe outlet, (as i have used, not as a balance pipe, but feed for the Webasto) If needed, i can get that last 13 lts out of the aux tank California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
i meant the other end of the pipe being exposed as it would need to enter the main tank below its aux exit point which seems to mean below the chassis rails as chassis is in way of anywhere else. Cheers
