Home > Maintenance & Modifications > Fitting a side fuel tank to 110
jst
ok, have one of these (had it a while actually) just thinking about fitting it!
Anyone on here fitted one who could show me some pictures of where the balance pipe should enter the existing std tank?
i am struggling to see where to fit it where it is not exposed on the fwd edge but can be lower the output on the side tank. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #145238 16th May 2012 7:16am
James
email incoming with lots of pics and some dimensions (not from my 110 though... not got around to fitting my tank yet)
Post #145246 16th May 2012 7:30am
Defender_Td5
1991 Defender 110 300 Tdi USW Stornoway Grey
diesel_jim wrote:
James
Diesel_jim, would you mind forwarding that email to me as well? I am struggling too with these side tanks!
Regards
Rob
Post #145261 16th May 2012 8:52am
jst
cheers Jamie Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #145280 16th May 2012 9:52am
MartinK
diesel_jim wrote:
James
Jim - any chance of posting the pics on here??? I'm also looking for a longer tank range (not even getting 500 miles at the mo out of my 110)....??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #145287 16th May 2012 10:29am
spudfan
Ireland
Don't have one for the diesel but here is one for a petrol 110.Might be of some use to you.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #145312 16th May 2012 1:48pm
Naks
Why don't you go for a gravity tank? Simple, no fuss with extra pump, etc? --
Post #145315 16th May 2012 2:25pm
If anyone wants the info i've got here, fling me your email and i'll send it over (there's all sorts, some pics, some word docs etc)
Post #145329 16th May 2012 3:59pm
jst
i have a gravity tank, only issue is the output which feeds the main tank is not at the bottom of it, hence requirement for a balance pipe. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #145417 16th May 2012 9:05pm
walfy
Why not fit a small external fuel pump to transfer the fuel between the 2 tanks. Not an ideal solution but better than snagging exposed pipes 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #145425 16th May 2012 9:14pm
leeds
Hi James, sorry has been hectic at moment with the aftermath of a show but have managed to take a few photos for you.
Not the easiest thing to photo the pipes with chassis/tank guards etc.
Black 110 has a 120 litre main tank plus wing tank
Breather pipe goes over chassis rail to main tank
Connecting pipe leaving wing tank
Pipe going into main 120 litre tank
300TDi wing tank plus standard fuel tank.
Filler pipe from wing tank
The 300 TDi has been on for many years with no problems.
HTH
Brendan
Post #145427 16th May 2012 9:26pm
jst
Excellent, thank you Brendan.
the photos show it as i had imagined it would have to go when i offered the parts up.
i was trying to come up with a more protected route and am yet to source one. I am also not too keen on drilling into the original plastic tank! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #145434 16th May 2012 10:14pm
leeds
With a plastic tank to get the fitting in place, after drilling the hole, pass a wire through the hole and fish it out at the pump opening. Slide the fitting along the wire and out of the hole
Have never had problems with the pipes from the wing tank, and as you are aware we do drive off tarmac.
Before people consider a wing tank, please consider the state of your main tank. If the main tank is getting past its better, rather then adding a wing tank it may be better to consider a new larger main tank as it may be a cheaper option.
Brendan
Post #145435 16th May 2012 10:31pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
jst wrote:
...only issue is the output which feeds the main tank is not at the bottom of it, hence requirement for a balance pipe.
what is balance pipe ? Embarassed ....I'm thinking of acquiring one aux fuel tank very soon.... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #145483 17th May 2012 10:45am
jst
if the output from the aux tank to the main tank is not at the very bottom of the aux tank you end up with a residual amount of fuel - 5-8L on a side tank? stuck in the aux tank below the output.
the balance pipe is a pipe (small bore) that runs from a point lower than the large output to the main tank.
consider its roll opposite to the breather in function and locations. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #145527 17th May 2012 1:49pm
