![]() | Home > Off Topic > Tap and die set. |
| Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587
A few years back I picked up this set which covers M3 to M12 including M3.5. I didn't expect much but it has been really good for my occasional needs.
http://www.axminster.co.uk/28-piece-metric-tap-die-set-300155 |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11094
Thank you everyone, really great information from you all and i'm learning yet again
I'm in the mind to buy a set, as i would rather it be waiting to be used rather than waiting to get the bit i have not got I did mention this to someone i know and they recommended a set from Facom, does anyone know if they are any good ? many thanks. Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18050
Facom make top quality tools at top quality prices.
Many thanks blackwolf
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
Used my Draper taps again today for cleaning threads of torque convertor from Loctite and re-threading exhaust manifolds for new studs.
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
This is what happened to me:
Bought cheap set and used only two of them regularly until I finally snapped one in the work (!). Bought replacement at quality shop, realised the difference, bought standard, intermediate and bottoming taps in those two sizes and a few more as need arised. The original set never gets used except perhaps for the dies when I need to clean up a stud or extend the thread on a bolt etc. Very bodgy! In general though, taps are used much more often than dies. I also discovered since the style of tap for through-hole threads that lets you just hand drill them straight through (in soft metals) - it's designed such the swarf falls downward, rather than spiral up. I'll hunt out the design, great time saver in certain circumstances. Conclusion: if it were me again, I'd buy quality individual taps with appropriate decimal drills (*) as I need them - perhaps a cheapy too and push it harder on some scrap stock to see how early it breaks, you'll get a feel for it that way. * oh and a pitch gauge and vernier calipers Solved the bowel problem, working on the consonants... |
^^threads on bolts are directly formed and then perhaps galv coated/hardened etc.
'Cleaning' them with a die (as I do myself) almost always results in swarf, whose removal could (?) lead to unintended consequences like corrosion and loss of strength. Not that I've ever had anything bad happen personally, but I just note it ... Solved the bowel problem, working on the consonants... |
Many thanks agentmulder for the info, much appreciated
As Agentmulder says, almost all bolts and setscrews now have rolled threads. Whilst it is OK to clean them with a die or die-nut it is not advisable to cut the thread of a bolt longer. Get one the right length to start with.
Many thanks for all the info
Just to update everyone who has been very helpful with all there info, i took all of that aboard and i have gone and bought this to start me off ................................
Click image to enlarge Many thanks to everyone 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
| Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 889
Horses for courses? I clean up or "chase" bolts (for example when changing the anodes on my boat) with a die-nut, but I wouldn't attack them with a split die.
Peter |
| All times are GMT |
