Home > Off Topic > Tap and die set.
Page 2 of 2 <12
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
A few years back I picked up this set which covers M3 to M12 including M3.5. I didn't expect much but it has been really good for my occasional needs.
http://www.axminster.co.uk/28-piece-metric-tap-die-set-300155
Post #672013 19th Dec 2017 3:12pm
Siwynne
The Axminster set comes up as a powercraft set in Aldi every now and then.
My dad is a retired toolmaker and proper fussy about tools. we have tool boxes full of taps and dies all top quality. This was a cracking little set and he thought was brilliant value and decent quality so bought two.
Post #672022 19th Dec 2017 3:46pm
L110CDL
Thank you everyone, really great information from you all and i'm learning yet again Wink
I'm in the mind to buy a set, as i would rather it be waiting to be used rather than waiting to get the bit i have not got Rolling Eyes
I did mention this to someone i know and they recommended a set from Facom, does anyone know if they are any good ? many thanks. Clayton.
Keeper.
Post #672351 20th Dec 2017 9:44pm
Facom make top quality tools at top quality prices.
Post #672369 20th Dec 2017 10:31pm
L110CDL
Many thanks blackwolf Thumbs Up Clayton.
Keeper.
Post #672390 20th Dec 2017 11:30pm
Romadog
Used my Draper taps again today for cleaning threads of torque convertor from Loctite and re-threading exhaust manifolds for new studs. Thumbs Up
Post #672509 21st Dec 2017 7:03pm
agentmulder
Kuwait
This is what happened to me:
Bought cheap set and used only two of them regularly until I finally snapped one in the work (!).
Bought replacement at quality shop, realised the difference, bought standard, intermediate and bottoming taps in those two sizes and a few more as need arised.
The original set never gets used except perhaps for the dies when I need to clean up a stud or extend the thread on a bolt etc. Very bodgy! In general though, taps are used much more often than dies.
I also discovered since the style of tap for through-hole threads that lets you just hand drill them straight through (in soft metals) - it's designed such the swarf falls downward, rather than spiral up. I'll hunt out the design, great time saver in certain circumstances.
Conclusion: if it were me again, I'd buy quality individual taps with appropriate decimal drills (*) as I need them - perhaps a cheapy too and push it harder on some scrap stock to see how early it breaks, you'll get a feel for it that way.
* oh and a pitch gauge and vernier calipers Solved the bowel problem, working on the consonants...
Post #672519 21st Dec 2017 7:56pm
agentmulder
Kuwait
^^threads on bolts are directly formed and then perhaps galv coated/hardened etc.
'Cleaning' them with a die (as I do myself) almost always results in swarf, whose removal could (?) lead to unintended consequences like corrosion and loss of strength. Not that I've ever had anything bad happen personally, but I just note it ... Solved the bowel problem, working on the consonants...
Post #672523 21st Dec 2017 8:13pm
L110CDL
Many thanks agentmulder for the info, much appreciated Thumbs Up Clayton.
Keeper.
Post #672546 21st Dec 2017 9:48pm
As Agentmulder says, almost all bolts and setscrews now have rolled threads. Whilst it is OK to clean them with a die or die-nut it is not advisable to cut the thread of a bolt longer. Get one the right length to start with.
Post #672573 22nd Dec 2017 12:08am
L110CDL
Many thanks for all the info Thumbs Up Clayton.
Keeper.
Post #673157 24th Dec 2017 8:44pm
L110CDL
Just to update everyone who has been very helpful with all there info, i took all of that aboard and i have gone and bought this to start me off ................................
Many thanks to everyone Very Happy Thumbs Up Clayton.
Keeper.
Post #692672 11th Mar 2018 9:44pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Horses for courses? I clean up or "chase" bolts (for example when changing the anodes on my boat) with a die-nut, but I wouldn't attack them with a split die.
Peter
Post #692837 12th Mar 2018 4:50pm
Page 2 of 2 <12
