Home > My Defender > V8 90 Soft top thread! at last!
Page 4 of 12 <123 45 ... 101112>
mikeh501
im not sure i could do another lol; although i was looking at buying a 30 year old porsche which needed a rebuild Very Happy glutton for punishment lol
Post #672281 20th Dec 2017 5:54pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
If you want to empty your bank account then a 30 year old Porsche which needs a rebuild will certainly do it Rolling Eyes
Post #672314 20th Dec 2017 7:49pm
mikeh501
from personal experience??? Very Happy
Post #672316 20th Dec 2017 8:00pm
mikeh501
On four wheels….nearly
Its a bit of a snowball from here, and anybody who’s done will tell you that its hugely satisfying getting the thing sitting on its wheels when starting from a box of bits! All this went pretty fast and I didnt have tons of photos for some parts of the build up.
The next step was to build up the stub axles on the rear, and the swivels and housing at the front ready for final assembly of bearings and fittings of wheels etc. Exciting times!
So, onto the diff. Started with the front diff which I got a casing from the garage I used and then had them fit the Ashcroft ATB to this diff housing and ring gear. I then refurbed and painted the diff case before fitting. My paint combo of choice on steel is dinitrol converts rc900 rust converting primer, and then trustbuster expoxy mastic 1-2-1 in black 2 pack paint.
Now onto the rear end. Stub axles fitted, and bagged up to stop crap getting on the surfaces before fitting the hubs.
Front end time. Cant find any pics of the buildup of the swivel balls and swivel housings. I may have been too greasy to get the camera. Basically similar to before, I completely refurbed the housings and painted them. New swivel balls and retainers and new OEM bolts etc etc. Some cheapo CV’s (which I may live to regret but hey ho) and new stub axles, callipers and discs Very Happy This is very shiny!
New fuel tank! mine was holed by someone who decided it would be a good idea to drill the floor! then they filled the hole! after 1/2 tank it started to leak!
Tank has been seam sealed around the middle, then painted with epoxy 1-2-1 and finally had dinitrol applied around the seams where they always tend to let go.
Post #672345 20th Dec 2017 9:30pm
L110CDL
I think that all the love and attention to detail that you have done so far, can not be punishment Laughing surely all pleasure Very Happy Clayton.
Keeper.
Post #672371 20th Dec 2017 10:33pm
SWR
Looks like you are making excellent progress.
Keep the updates coming!
Post #672395 20th Dec 2017 11:50pm
defender9
No, it took a long time to find an old 911 in original condition that didn't a rebuild but I know quite a few folks who have gone down the rebuild route and to do it properly you need very deep pockets Thumbs Up
Post #672440 21st Dec 2017 11:18am
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Amazing project and a brilliant thread! Really looking forward to see it all take shape! Thumbs Up Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #672453 21st Dec 2017 1:08pm
Romadog
Not going for a rear tank then??? Whistle
Post #672507 21st Dec 2017 6:55pm
mikeh501
did wonder about that, but went with the side one because my tub has the filler at the front. Also, I wasnt sure how the efi pump works on a rear mount tank. On the side mount you use a rr classic pump which fits the older tdi tank.
Post #672532 21st Dec 2017 9:17pm
mikeh501
Brake lines and breathers time!
I bought the gwyn lewis breather kit for this build. Really nice kit including new breather fittings for the axles which you have to tap out. Id also decided to pretty do the whole of the braking with stainless hose rather than copper. I didnt have the copper pipe tools, and it wasn’t big money to just use stainless braided hose instead ordered to size from Llama 4x4 in shropshire! << that guy can talk, dont call unless you have an hour!
Brake lines, and finding the routing for this was a bit of a mare.
Post #672534 21st Dec 2017 9:20pm
Romadog
Interesting brake lines.....any more info....website is s***e.
Thumbs Up
Post #672540 21st Dec 2017 9:39pm
mikeh501
dont rally have much more info apart from you can order brake lines of any length with different angle ends and they arent crazy expensive. I forget where I got the guys name from, but hes the same guy who runs the donnington 4x4 show each year. To be fair I think you can source these things from anywhere, the trick is knowing what you want!
Post #672542 21st Dec 2017 9:42pm
Is it the Llama dude?
Post #672569 21st Dec 2017 11:34pm
mikeh501
Yeah, talk the hind legs off a donkey
Post #672585 22nd Dec 2017 12:48am
