Home > Technical > Puma Glow Plug Operation
X4SKP
Gentleman I'm looking to understand the Glow Plug operation on a Puma, to identify if I currently have a problem...
or one developing.
I know it's been cold, but how long is 'too long' when the Glow Plug light is lit, before it goes out, and if the 'control' of this operation is faulty, how would we know, and what could cause a 'long duration' glow light operation... Question
Mine currently is lit for around 5-6 seconds, which feels long, and I would say has extended over the 4 years I've
had the vehicle... Normal or Not... Question
Whilst I believe the approach, 'if it anit broke dont fix it'... dosn't really apply to Land Rover ownership,
what is normal here, and if mine is 'lighting' up the Glow Plugs for too long, what could cause this... Question
Could a Faulty Glow Plug 'Operation' cause a non-starting Puma... Question
Occasionally I experience a non-starting Puma (MY 2011 2.4). She can start 50 times OK then nothing,
often then immediately restarting if 'switched off' (although not running) and switched on again.
I have had this 'issue' for a year, and have tried and resolve it by undertaking the following...
All Main Earth Points checked (off cleaned and positively reattached)
New Main, Starter and Glow Plug Relays
New OEM Starter Motor
New OEM Battery
Key Fob Battery's Replaced
Lucus 10AS Alarm (out contacts cleaned and replaced)
I have No (visible) Water ingress within Dash area
No Fault Codes on Scangauge II
I'm about to take delivery of and fit a New Ignition Switch...
https://www.lrdirect.com/LR039638-supplied...LUCAS.html
So after my last year of Defender ownership I was wondering about this light...
Thanks... SKIP
Post #672199 20th Dec 2017 11:57am
dorsetsmith
Post #672204 20th Dec 2017 12:23pm
dorsetsmith
Post #672205 20th Dec 2017 12:24pm
X4SKP
Thank you dorsetsmith
Perfect... Thumbs Up I may well have no issue here as i'm < 8 Seconds (at around -3 degrees morning temp)
Occasional Non-Starter
May be, as I know she will be a non-starter from time to time i'm just looking around, to hopefully
'stumble' across the cause, and solve my issue.
I'm continuing with the approach, change one thing and test...
again thanks... SKIP
Post #672207 20th Dec 2017 12:41pm
dorsetsmith
New Ignition Switch. good place to start with
glow plug can fail and will not report Fault Codes you will have test then one by one
Post #672211 20th Dec 2017 1:07pm
X4SKP
Hi dorsetsmith
If it does turn out to be the Ignition Switch...I only wish I had started there... Exclamation
Intermittent problems I hate...break and stay broke... SKIP
Post #672238 20th Dec 2017 3:40pm
williamthedog
Also the transducer coil around the switch plays up too Rolling Eyes
Post #672335 20th Dec 2017 8:52pm
