Home > Maintenance & Modifications > Rear work lamp
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Rear work lamp
I am thinking of putting a rear lamp on the back above the door and simply wiring it into the reversing lamp. I have window tints so can't see much in the dark when reversing at the minute. Would this wiring idea work? With the ignition on I can pop into reverse to use as normal lamp too.
Also, any recommendations for a light, LED maybe? Thanks.
Post #671352 16th Dec 2017 11:45pm
grafty99
Basically it needs to be on a separate illuminating switch to be legal. Whichever way you do it however it's best practice to use a relay.
Many people wire them in through a three way switch so you have
Auto (on with reverse)
Off
On (manual)
If going led then a relay isn't needed Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #671355 17th Dec 2017 12:00am
grafty99
Scenelight is a good option. Ray (mk1collector) on here has just fitted one. See his excellent thread > http://www.defender2.net/forum/topic17615-765.html Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #671356 17th Dec 2017 12:02am
donmacn
If I understand you right, you're talking about having your work light switched on/off when the vehicle is put in/out of reverse gear?
I think that would be quite restrictive and maybe a bit impractical. Better to find an alternative power source and allow it to be switched independently.
I'll be fitting a scenelight shortly I think, and I'll try and gave that switched at the light.
I currently have one switched from the front dash, but I ran power up the A pillar and along the side of the roof (I had the headlining out at the time anyway).
Post #671357 17th Dec 2017 12:03am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Another vote for the Scenelite Thumbs Up
I've set mine up to be operated by a switch on the steering column cowl, so it's easy to reach should I need it whilst reversing. Was easy enough to feed the wires up the a pillar and tuck behind the trims to get to the back door.
I think www.exmod.co.uk have them on offer at the moment 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #671434 17th Dec 2017 12:32pm
dgardel
Italy
Scenelite here!
I wired mine with two switches, uno on the cubby box and the second on the rear, closer to the Left loudspeaker.
Below you can see the electrical diagram.
With the cubby box switches (ON-OFF.ON) you can select:
1. Rear lamp ON
2. Rear lamp OFF
3. Rear lamp ON with reverse
with the rear one you can switch on the lamp
and, yes, very good quality, very nice style and powerful....
here the wiring schematics
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #671578 17th Dec 2017 10:40pm
