![]() | Home > Off Topic > My RRC project |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
No not really, just getting odds and ends as I go. I'm mainly refurbishing
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
The replacement valley gasket and sump sealer have arrived this morning. Hopefully I will get them fitted this weekend and get the engine in place
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11063 ![]() ![]() |
Your moving at a good pace there grafty
Yeah getting there, looking forwards to getting stuck into the shell
It's a good thing i dont live closer to you, i think i would be living there, helping you all the time and learning about the RRC
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
You're welcome any time
![]() ![]() ![]() Cons are obviously no V8 loveliness ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I thought you might take the plunge and put in that other V8 lump that we talked about
![]() ![]() Answer to your Q is V8 loveliness ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Yeah I was thinking V8 loveliness. The Td5 can go in the other one
Cant you put the " other V8 lump " in the black one
![]() If you made it into a pick up i could use it for work ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Could do I suppose. Don't think I'll be doing a pickup though I'm afraid
![]() The engine is in ![]() ![]() Click image to enlarge ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Today has mostly involved dishwashing (more on that in a moment). The story starts with the geabox. 8 years of sitting still (and also 5L of highly tuned V8 going through it) had taken its toll on the Range Rovers original gearbox. This meant that I needed to fit the autobox out of the donor car as it only had a 200tdi going through it so was in much better shape.
The problem, however, is that it had an LT230 transfer box on it and I wanted the chain driven original as it has viscous limited slip centre diff. This required a change of output shaft and rear end housing on the gearbox. Unfortunately to swap the output shaft over required a full strip down - of both gearboxes ![]() So I decided that as I was going to be stripping the boxes down anyway I may as well give the one I was going to use a bit of a tidy up. To get the gearset out of the casing the valve body and flow restrictor rubbers needed removal. So after about an hour I ended up with this: ![]() Click image to enlarge ![]() Click image to enlarge This left me with a surprisingly light outer casing: ![]() Click image to enlarge This is where the dishwasher comes into place, a couple of tablets on a 95°C wash yielded this: ![]() Click image to enlarge ![]() Click image to enlarge Don't worry, it's the workshop dishwasher ![]() Anyway I can't test it until I've put the RR mostly back together but fingers crossed! ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
