Home > Technical > Main relay on Defender? ** Car still randomly cutting out **
Page 4 of 5 <12345>
X4SKP
Hello Stacey007
I may have missed the outcome of this... but how did you get on... Question
And was it possible to fit...
without removing the complete ignition barrel... Question
Also did you go OEM Land Rover £60ish, Lucas £30ish...or Britpart <£10... Question
Hope you are up and (continually) running again... Thumbs Up SKIP
Post #670881 14th Dec 2017 12:46pm
Stacey007
Hello
Nothing to update as it's still cutting out now and again Sad but I've changed nothing....
My Series III is almost ready to leave the garage then this is booked in.
I have a new ignition switch, Garage bloke has a new MAF that he said will fit also then it needs front Brakes and Pads.
Once this is done will report back. Its been fine for another week, yet last week it cut out 3 times in 10 mins...
Very odd Smile
Post #670883 14th Dec 2017 1:05pm
X4SKP
Hello Stacey007
Well good luck... Thumbs Up
OEM Switch or Factored Part... Question
'Sorry'...best attempt at a summary...
I too have an interest in this area, occasionally I have a non-starter, it has never cut out while running (or worse while driving... Exclamation ) I checked near enough everything (short of checking the complete wiring loom) I did however check 'continuity' between each point and voltage at all key points. I then (out of frustration) changed the Starter Motor and Battery, after first returning the 'Truck' (there is a diliberate typo there... Exclamation ) to 'Stock', so removing a Battery Isolation Switch (on Starter Motor), an XDefend Steering Lock (as it requires the repositioning of the 'Ignition Fob Coil' out of its factory position)...All made no difference...occasionally a non-starter. Main and Starter Motor Relay's were also replaced.
I became convinced that one connection on the rear of this Ignition Switch was to blame as when not starting I removed the instrument cluster, again...(i'm <10minutes now... Mr. Green ) and when removing cleaning and replacing the White Red wire..it always starts (well always so far).
So what am I actually doing by removing cleaning and replacing this particular wire... Question i'm not sure, maybe i'm just 'disturbing' this part of the ignition switch, and mines 'on its way out'...Slowly
My approach... somewhat 'trial and error' is to change one thing and see, as the only thing I trust is the experience of use (over a reasonable time period).
Un-related (but maybe not)...I also looked back to 'what I did and when' and I noticed that up to fitting my ScangaugeII I had no issues, I'm don't think (or believe) that this is to blame, but I have unplugged it from the OBDII Port for 1 week now, and had no issues starting so far. I would generally get a hesitation or more typically a straigt non-start once a fortnight, with the vehicle used daily.
So I remain on a quest to solve this...and I can see that (to eliminate this component) I well may swap over to a new Ignition Switch (rear element) to add that too, to my list.
To their 'credit' Land Rover did show real reluctance to 'take a look at this' as at £150 / Hr exc. VAT (at my nearest) I think they felt it would test the financial tolerance of this (or any) customer. Or they may know these can be a Censored to fix sometimes...who knows. SKIP
Post #670892 14th Dec 2017 2:36pm
Stacey007
Skip
I asked the garage should I get the OEM part or non genuine he said get the non genuine. Without hesitation so I have, he seems to think quite straightforward to fit. I do hope it fixes it....
Keep me updated how yours finding goes Thumbs Up
Post #670898 14th Dec 2017 3:08pm
X4SKP
Hi Stacey007...Thanks
Will do, and yes I hope you get your fix too... Thumbs Up
I'm probably here, mid way on the price curve, also I've had no bad experience so far with Bearmach
and the Ignition Switch / Complete Ignition Barrel is I think a LUCAS bit of kit from the 70's, so
sticking with that bang up to date 'vintage componentry' ...
https://www.lrdirect.com/LR039638-supplied...LUCAS.html
Good Luck SKIP
Post #670900 14th Dec 2017 3:45pm
X4SKP
Ignition Switch Swap
Well took delivery of my LUCAS Ignition Switch and thought I'd swap it out...I mean how difficult could it be... Question
I'm doing this on a MY2011 2.4 Puma so my suspicion is that most if not all 2.4's will be similar if not the same.
Whilst as Martin rightly states the instructions for this procedure imply a single retaining screw and that it is possible to do the swap without removing the main Ignition Barrel...I think, from my experience this is near enough impossible...as pictures tell the story better, if your faced with needing to do the same, here's what I did...at each 'now what do I do moment'
First step was to remove the 'single' retaining screw...
I used a magnetic to turn and 'capture' the final undo...drop it and it's gone... Exclamation
Second step was to 'ease' out the Ignition Switch...
but No it moved slightly but it is clear quickly that there is more going on here... Exclamation
Third step coffee and good think...
forcing my hand round the back of the Main Barrel and just getting my fingertip onto the 'hidden' screw, i decided that I was going to clear the area, so everything got stripped away... Exclamation
Forth step...make the decision to get the Main Barrel (and Ignition Switch Assembly) out...
checked first that the retaining bolts are M8
Fifth step, 'drift' out the right hand Bolt...
I knew at this point that the left hand Bolt was more tricky as the angle of 'attack' on a Puma is just too acute, with the centre punch (in my case) lying over at not an ideal angle. The right Bolt as soon as it moves actually comes out OK. I suspect that for a TD5 or 300 / 200 TDIs without the Puma 'shelf' both Bolts are more accessible...but in Puma world things are different... Exclamation
Sixth step inspect Security Bolt...complete with Lock Tight...
Seventh step confirm what you already know the left hand Bolt is altogether a different task...
I really tried thinking that it would eventually undo, I tried all my punches even bending one to try and get a better approach...but No I just couldn't get it to move... Exclamation
Eight step drill a 20mm hole in the top right hand corner of the Main Fuse 'area' this hole would be covered (hidden) by both the Fuse access cover (Door) and also the rubber inlay on the shelf...so after another coffee and a good think I committed... Exclamation this shows looking up though the Fuse area and onto the left hand Bolt...
Ninth step drill a receiving hole for an e-z out bolt extractor...
Tenth step set up the e-z out, mine has a 18mm dia main shank which set the drilled hole size of 20mm through the Dash, this hole dia was also required for the Pilot hole drill extension rod I used. I also had a 20mm rubber grommet in line to use but ultimately didn't need it... the left hand Bolt came out really easy...
Eleventh step with the Main Barrel now 'free' was to withdraw it...but No... Exclamation
What became clear is that the 'weeding' of the main Dash (Holes cut in) are more to aid assembly at LR Not to aid Maintenance, the Main Barrel needs to be lifted around 10mm to disengage the steering lock from the column, it also need to be 'rolled out' to allow its shape to clear the steering column...after another coffee I decided that more 'surgery' was required on the Dash to make things 'right' (LR... Exclamation ) you can see the marked up area to be removed matching the area on the right...
Twelfth step surgery completed (but not tidied up)
Thirteenth step Main Barrel now is free to be withdrawn and for the first time free enough access to the rear connections which are a positive 'click on' type connection so require good 'hands on' feel to disengage, so another reason in support of getting the Main Barrel out...
Fourteenth step get a good look at that second screw... Exclamation
Fifteenth step swap over Ignition Switch...
Sixteenth step 'adjust' down the diameter of the two replacement Bolts this show two standard SS Dome head Bolts, I put back Security versions, although I question if security bolts are even needed here, as I doubt they add much
Eighteenth step...put it all back together...and she starts first time... Thumbs Up
I really hope I have solved my intermittent starting problem with this Ignition Switch Swap...doable but not untypically more to it when you actually come to it... Shocked SKIP
Post #672697 22nd Dec 2017 6:54pm
Stacey007
Wow skip...
That looks like a job a fair few choice words may be used...
Great pictures, I'm planning on the garage doing it when I take mine in...
Has it helped? / stopped as yet
thanks Thumbs Up Thumbs Up
Post #673602 27th Dec 2017 3:57pm
X4SKP
Hello Stacey007
Thanks...Well so far so good, but I have learnt to reserve judgement regarding this issue, as I have lived and 'pursued' my intermittent starting problem for a year now, and only time will tell....1 in 30+ starts failed, often then starting on the next attempt, so when you have only this to go on, and no reliable 'testable' failed condition, it (for me anyway) has proved a real headache... Shocked
I have deliberately use the Defender for every trip possible over the Holidays, so it has been started maybe half a dozen times a day for the last 7 days, and I have a feeling that I may be lucky now and have fixed my 'doggy connection'... it defiantly triggers the Starter Motor quicker when on position III, which of course could be just new contacts making a more positive connection... Thumbs Up If it does persist i'm running out of things to replace... Shocked
If I have fixed my problem then the 'take away' from this is list everything you think it could be and work through them in order of from the least expensive to the most expensive... Exclamation if your really lucky (unlike me) it will break and stay broke and and a good hour or so later with your Multi Meter and you would be able to isolate most reasons for a non-starter.
Good luck with yours... I'm still not sure what the Ignition Switch does after 'Ignition'...would (could) it 'deliver' your symptoms...cut out a running engine, someone on here will know, but it seams to me unlikely from my understanding of it, I guess you could check by disconnecting various wires when running and see on the assumption you are probably only replicating your cut out scenario...i'd just want to know that by doing this you would not be causing any damage to the engine (and I don't know that to be the case) but i'd be tempted to try...or just spend the £30 and swap it over and prove by long term testing... Thumbs Up SKIP
Post #674153 29th Dec 2017 6:12pm
Stacey007
*** Update ****
O k so I think (and hope) its been a while since I have had the new ignition switch fitted and while it was in he had a new Maf Sensor off a car that ordered it but didn't need so he put that on.
I've probably driven 2000 miles since including just done the Lakes and back for week driving around.
100% its been great Thumbs Up actually driving better than even (what are these trucks limited to?) Its driven really well.
2 things could be better...
It still vibrates around 54 mph and garage thinks it is the wheel spacers as nothing else is worn / not been changed.
These is also around the same speed a sort of hesitation.. like its hunting but you drive right through it either below or over this speed? Very odd.
Other than that the car drove really well just wanting to 'go' even loaded up with camping gear Thumbs Up
so fingers crossed
Post #700627 13th Apr 2018 7:52pm
X4SKP
Hello All,
Quick update...almost a year on and no reassurance of my 'will she wont she start' phase of ownership.
Mine never died when running, it only ever made up its mind to start or not, when the key was turned...
100% Ignition Barrel failure, 'breaking down internally' with a so-so connection. SKIP
Post #730183 20th Sep 2018 6:17pm
Stacey007
Great news !!!
I'm please mine was a relatively easy and cheap fix. Although very un-nerving the car just losing all power and dials then coming back on Smile
Post #730190 20th Sep 2018 7:05pm
marcoegyptos
France
Hello ,
After two or three years of similar problem , the car use to start and stop immediately , I was obliged to switch off the positive battery cable and the car restart without problem .
Last summer, I disconnect the Scangauge and since that time, I don't have any more problem of starting .
This can help .
Post #730222 20th Sep 2018 9:06pm
blurry
Martin wrote:
The OEM (non LR branded, same part) of the switch is about �17 rather than �57
""""""There's not one single "main relay" which controls ignition switched circuits, the switch itself handles the most of the power. There is an additional ignition relay controlled by the main switch but that is for the wipers/washers, and heated seats/electric windows (if fitted).""""""
The engine ECU detects the ignition coming on and then powers up its own relay.
Sounds like it might be the switch, with the ignition contacts opening up and cutting the power.
Hi Martin,
Came across this thread while trying to find out why a have a new problem, puma 2.4tdci, which includes the loss of power to elect heated seats (switches no longer illuminate) Heated front screen (switches no longer illuminated), elec windows no longer work, heated rear screen (switch also no longer illuminated), wipers no work, dipped headlights no work ecept on flash main beam. Instrument panel is dead, no ignition lights and no trip computer, alarm light works, indicators work, sidelights work, hazard lights work, radio works and heater blower works.
Van starts with no issues, and the central locking and alarm works too.
All fuses have been checked and are fine.
The problem occured when swapping a couple of relays around to see if one was faulty, the relays were the 4 pin 40amp ones.
What/where is this 'additional ignition controlled relay by the main switch that you mention please?
Post #875100 29th Dec 2020 8:32pm
Martin
Site Admin
Intermittent loss of these things or have they gone completely?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #875112 29th Dec 2020 9:31pm
blurry
Hi Martin,
At the moment gone completely.
Post #875145 30th Dec 2020 12:13am
Page 4 of 5 <12345>
