![]() | Home > Puma (Tdci) > Matrix |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
Bubbles in the expansion tank might be a head gasket gone - get a 'sniff test' done at a local garage to check for combustion gasses in the coolant
Matrix is a dash out job I believe Keith |
noticed water on the passenger mat
more likely to be rain water see link below https://1drv.ms/b/s!AtZSoWFHDgnGhERwdB-0XcdTS_UI |
Norfolkboy1 Member Since: 10 Dec 2017 Location: Norfolk Posts: 2 ![]() ![]() |
I have checked obvious signs for head gasket such as no white smoke from exhaust, oil cap has no creamy white -looks normal. Oil looks very dark and normal.
I will get it tested at garage Any other suggestions apart from head gasket? Regards to possible water leak thank you for the link to information kind regards |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
If you have antifreeze in your cooling system then a quick taste of the water on your mat should identify water coming from the cooling system. Just a quick lick of a dipped finger, as antifreeze is supposed to be harmful, but probably only if you drink it by the pint!
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
+1 a lil bit is alright!
