Home > Puma (Tdci) > Matrix
Norfolkboy1
Matrix
Please go easy on me I am a newbie!
I am looking for a bit of advice from the experts on here.
I believe my matrix has failed as the last few months I have noticed water on the passenger mat. Just recently my heater has failed, only blows hot when accelerating, I have also noticed bubbles/foaming in expansion tank. Would I be right in thinking that the matrix is the culprit?
Also does the dash have to be fully or partially removed to replace matrix?
How many hours would this take a mechanic and what's a fair price to pay?
Many thanks
Post #670106 10th Dec 2017 6:16pm
ickle
Bubbles in the expansion tank might be a head gasket gone - get a 'sniff test' done at a local garage to check for combustion gasses in the coolant
Matrix is a dash out job I believe
Keith
Post #670113 10th Dec 2017 6:27pm
dorsetsmith
more likely to be rain water see link below
https://1drv.ms/b/s!AtZSoWFHDgnGhERwdB-0XcdTS_UI
Post #670115 10th Dec 2017 6:30pm
Norfolkboy1
Gasket
I have checked obvious signs for head gasket such as no white smoke from exhaust, oil cap has no creamy white -looks normal. Oil looks very dark and normal.
I will get it tested at garage
Any other suggestions apart from head gasket?
Regards to possible water leak thank you for the link to information kind regards
Post #670130 10th Dec 2017 7:23pm
Balvaig
If you have antifreeze in your cooling system then a quick taste of the water on your mat should identify water coming from the cooling system. Just a quick lick of a dipped finger, as antifreeze is supposed to be harmful, but probably only if you drink it by the pint!
Post #670134 10th Dec 2017 7:29pm
bankz5152
+1 a lil bit is alright! Laughing
Post #670189 10th Dec 2017 10:25pm
