Home > In Car Electronics > Passenger rear tail light
Rad666
United Kingdom 1998 Defender 110 300 Tdi DCPU Keswick Green
Passenger side tail light has an intermitent fault where it doesnt work but the brake light does. Its an led unit, it works when plugged into the driver side. Ive replaced the chassis loom for a brand new one from autosparks. And ive cleaned the earth point in the engine bay to and checked all fuses on the dash
Is there anything obviousr ive missed?
Post #667656 29th Nov 2017 3:57pm
geobloke
Is the LED unit a bulb or a complete unit like you get in the LED upgrade sets?
Are you getting 12v to the plug or unit?
Post #667670 29th Nov 2017 4:32pm
Rad666
Wipac unit and the brake light part works havbt had chance to test yet
Post #667671 29th Nov 2017 4:35pm
dorsetsmith
check connect behind Rh rear trim panel the Passenger rear tail light wire links up with the trailer socket at this point
Post #667672 29th Nov 2017 4:35pm
Have you checked Earth continuity and for voltage using a Multimeter?
From there, you can roughly I.D. The issues, and start to trace from there.
It could possibly be high resistance on the connector pins also, ensure they are clean and dry. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #667675 29th Nov 2017 4:39pm
Rad666
Just put test on and im not getting 12v to the plug Sad Ive checked and tested all fuses inside the cab and cleaned the earth that comes off the three plug loom and bolts to the bulkhead.
Any ideas where to look next
Post #669765 8th Dec 2017 5:29pm
Rad666
Is there a connector to join?
Post #669767 8th Dec 2017 5:39pm
dorsetsmith
Post #669773 8th Dec 2017 6:23pm
Rad666
So its already joined? Ive just been reading your old posts, i think i might have alook behind the dash
Post #669776 8th Dec 2017 6:37pm
