![]() | Home > In Car Electronics > Passenger rear tail light |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Is the LED unit a bulb or a complete unit like you get in the LED upgrade sets?
Are you getting 12v to the plug or unit? |
| Rad666 Member Since: 21 Jun 2016 Location: North yorkshire Posts: 89
Wipac unit and the brake light part works havbt had chance to test yet
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
check connect behind Rh rear trim panel the Passenger rear tail light wire links up with the trailer socket at this point
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042
Have you checked Earth continuity and for voltage using a Multimeter?
From there, you can roughly I.D. The issues, and start to trace from there. It could possibly be high resistance on the connector pins also, ensure they are clean and dry. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Just put test on and im not getting 12v to the plug
Any ideas where to look next |
Is there a connector to join? |
So its already joined? Ive just been reading your old posts, i think i might have alook behind the dash
| All times are GMT |
