Home > Expedition & Overland > Poppy Conversion to a Camper
Page 2 of 17 <123 ... 151617>
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi Chris
not tis time !! Rolling with laughter
Last time I took canoes on the Brittany Ferry they paid us to take item !! -
( it was a sponsorship deal with the GB team ! )
going to be busy enough getting the inners fitted and not have time to play on the water. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #649516 11th Sep 2017 7:39am
wyvern
After the peterbourlgh landrover show we have added to the camper - now the proud owner of a swing round 270� awning from Tuff-Trek complete with the sides,
[url] http://tuff-trek.com/awning-systems.html [/url]
as well as buying 3mm black and lined wing mounted checker plating for poppy as I miss them for standing on.
Bumper has been shot blasted, galvanised and sprayed up in black gloss to match the other back parts of the vehicle.
Today I reconnected the day light running lights and added 2 more sockets to the undercuby box - its great to have the power supply feeding into the area for the heater so that I can make use of it to feed the sockets, I also added an on off switch to turn off the feeds when I am not using the vehicle as the 2 usb sockets have blue light feed and this will drain the battery if not driven regularly.
The heater has its first proper use and its great. very quite compared to the previous one. Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #651406 19th Sep 2017 11:33pm
Coatesyyy
Wow, that is some serious kit! Looking forward to seeing more.. Thumbs Up
Post #651537 20th Sep 2017 4:08pm
wyvern
update - November
Fitted a set of general grabbers on the 110 for the trip to Germany later in the month - Wow - they are SOOOOO much Quieter than the wranglers ! I�m not a fan of the Grabbers but will be getting some BGF�s ATR�s when I�ve completed all the camper refit. (Thanks to �Driver� and 'Davidej' for the tyres and wheels)
I like the look of the Wranglers but the noise for long distance is excessive even for me, this weeks run up from Cornwall to Heathrow was a very different drive.
I�ll pop the wranglers back on for the winter though as I think they may be better than the grabbers in bad weather.
All the rear seats are now out of the 110. The 3rd row seats out and ready for sale if any one would like them (see separate post on that)
2nd row seats are out and safely stored away for fitting when needed again when not camping.
Extended the sub-footer cable but need to do some diagnostics as the thing isn�t working ... so that will be a nights play sorting that out.
New wing checker plates fitted and look very good - 3mm is the way to go !!
Loaded up all the things we need to take for the fitting of the internal units in Germany, so have a load space empty of seats but now full of cooker, potty, sleeping bags, chairs and the awing sides all ready to go - where did all that space go! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #661444 2nd Nov 2017 4:31pm
What flavour of Grabbers do you have? Some of them (definitely AT2) are winter rated and so would be better than the Wranglers. Darren
Post #661450 2nd Nov 2017 4:56pm
JOW240725
Thanks for the update. How long is it away for the conversion work? James
Instagram @suffolk_rovers
Post #661451 2nd Nov 2017 5:10pm
wyvern
Hi Daren - the grabbers are TR and yes are winter rated but the Wranglers are MTR and snow rated too .. the Grabbers are a bit older then the Wranglers and don't have as much tread so think the Wranglers will be a little better in the winter mush .. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #661453 2nd Nov 2017 5:17pm
wyvern
In Germany having just had the internal units fitted and all done in less than 4 hours from arrival to drive away.
https://www.landy-ausbau.de/?site=build_complete
The fitting required all the seat fittings need to be removed then the bottom boards locate onto the protruding bolts.
The units waiting to be fitted
the bottom board with the bed board/table cut out after fitting
Fitting the units
Lower parts in place
All the units are secured onto the board or thought the wheel arch.
I am informed that the whole set up can be removed in about an hour and then the original seats re-fitted.
We left the workshop and drove to a quire place where all the kit we carry was then organised and neatly put away.
Job done !
Next stop was an overnight sleep in the german forest, which was fine, except our extra wide sleeping mats are too wide for both to fit on the bed board, - not a major problem as we slept fine each night but something to work on for the next trip away.
The sleeping bags and mats are in the floor well next to the units - (will take set of better pictures of the bed board and table set up later. )
Now we are touring the war sites in Yippes and have given the 110 a good shake down and a few tweaks with packing and all is good !
The heater is awesome !! works very very well and is quite, used minimal power and fuel even though it was on a full 12 hours overnight.
more pictures to follow. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #667319 27th Nov 2017 6:41pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Looks very nice!
Post #667355 27th Nov 2017 7:52pm
L110CDL
^^^ +1 Thumbs Up Clayton.
Keeper.
Post #667789 29th Nov 2017 10:15pm
wyvern
more photos of the new units fitted to the 110 ...!
A view of the back - long chest on the left, tall cupboards on the right, loo in the middle and tall unit behind the driving seat.
tall cupboard with large med and small cupboards
long chest
The loo in the cupboard
passenger side units - top and side opening
driver side units - top is accessible from inside the vehicle too
the floor doubles as a bed board ... which gives a generous sleeping area for 2
it also doubles as a table .... !!( The metal supports are only used when fitting the floor board as a bed and are removed when in normal use )
we used it all for a week and found that the system worked very well. there is enough storage under the front units behind the drivers and passengers seats to store a high lift jack and other long things. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #668192 1st Dec 2017 11:09am
steve E
Wales
Now that is Awesome
Love it Thumbs Up
Post #668195 1st Dec 2017 11:28am
L110CDL
^^^ +1 Bow down Clayton.
Keeper.
Post #668740 3rd Dec 2017 9:13pm
Sulisuli
Very impressive kit out Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #668744 3rd Dec 2017 9:17pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Loving that setup Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #668891 4th Dec 2017 2:32pm
