Home > Technical > Brake Disc shields
grafty99
Brake Disc shields
Ok so this is a question about my RRC project but is just as applicable to the defender. There are currently no brake disc shields fitted and I wonder how important they are. My concern is that muck could work its way in the void between the stub axle and disc and damage the ABS sensors. Any thoughts? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #668054 30th Nov 2017 9:26pm
roel
Dirt will get there anyway. I don't have abs but drive without them. This way I can clean it better after off-roading. Roel
2003 90 Td5 (2009-now)
Post #668092 30th Nov 2017 11:00pm
grafty99
I do have them on my defender but haven't noticed much dirt behind them, then again I don't do a huge amount off road. 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #668094 30th Nov 2017 11:03pm
jst
I remove them from our training vehicles and anything else that goes off road regularly, makes cleaning easier, bit leave them on the more road based vehicles. Helps keep the road Salt/grim off the latter Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #668159 1st Dec 2017 8:34am
grafty99
Right ok, so it seems as the Range Rover will be mostly on road biased ten it's probably a good idea to get some. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #668162 1st Dec 2017 8:43am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Many years ago when I had a RRC I took it into have a MOT and it failed as the shields had been attacked by the rust worm. I can't see why it would be a reason to fail unless it was classed as dangerous parts. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #668185 1st Dec 2017 10:44am
Devon-Rover
Offroad use the 'mud shields' just shield the mud from being cleaned off Laughing On my training vehicles when I do the first replacement set of bearings then I leave the shields off as this happens
Post #668187 1st Dec 2017 10:57am
grafty99
Well that pretty severe! Mine have never got that bad Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #668188 1st Dec 2017 11:00am
grafty99
I will probably key the new ones up and paint them in RCP and CIO buzzweld to prolong their life Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #668189 1st Dec 2017 11:01am
Devon-Rover
This is what greeted me on for a routine pad change and I was told the instructor had washed the vehicle hence the top of the damper and the bit of chassis is clean. Sadly they won't budget for Mach 5's to allow easy cleaning, and wonder why I can spend a hour pressure washing after I finish teaching, as I know what It's like.
Post #668215 1st Dec 2017 1:33pm
grafty99
Any time I go off road the wheels come off mine anyway to have a good clean so perhaps that's why I haven't really had a problem. Definately a nightmare to clean with the wheels on! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #668260 1st Dec 2017 5:43pm
grafty99
Just as an update, I went for it in the end, new brake shields fitted all round. Rubbed down and buzzweld primer and paint applied before fitting. Should last a while Thumbs Up
1990 Vogue SE
Post #670634 13th Dec 2017 8:33am
geobloke
Hi Grafty. Did exactly the same with Miffy, last month, after not having front guards for the last 5 years or so. Took them off initially as they were rattling. Post replacement no noticeable difference to anything, but I did note that the forward part of the guard is flared which I assume is to promote an increase of cool air across the disk whilst driving. Which must help... Maybe...
Post #670663 13th Dec 2017 12:10pm
grafty99
Yeah I reckon they'll promote some kind of brake cooling. I think it just looked bare without to be honest. And let's face it - landrover wouldn't have fitted them if they weren't needed Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #670669 13th Dec 2017 12:40pm
pannawonica
Australia
I’m not too sure what they actually do! Shield the discs against what? Mine are original and in good order with no rust, however can’t figure out what their true function is! Thumbs Up
Post #670679 13th Dec 2017 1:29pm
