Home > Off Topic > Relay car theft
Zed
Relay car theft
Post #667249 27th Nov 2017 1:19pm
dorsetsmith
Place the key fob in metal tin with lid and the black box at Censored theft are using with have trouble reading the code this is biggest problem with keyless entry to cars and thieves have worked this out and had the relay box made Exclamation Exclamation
Post #667258 27th Nov 2017 1:55pm
rustandoil
Apparently you can buy a "Faraday pouch" from Amazon to combat this £25 + though
Post #667262 27th Nov 2017 2:05pm
Zed
£25? They are only lined with tinfoil. You can get wallets and other pouches for a couple of quid on ebay.
Post #667264 27th Nov 2017 2:20pm
rustandoil
£25 is clearly too much, I was just quoting what I saw on another forum
Post #667268 27th Nov 2017 2:47pm
discomog
I use a McVities Faraday cage, works just as well and saved me £25.
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #667323 27th Nov 2017 6:52pm
Zed
Classy.
Post #667328 27th Nov 2017 6:58pm
Ade90
Plus you get to eat the biscuits Thumbs Up Fixing Land Rovers for over 25 years..........and making excuses to the wife for almost as long Smile
1984 110 V8 - Gone, but not forgotten....
Post #667330 27th Nov 2017 7:00pm
Swine&Small
Apparently leaving ones keys in the fridge can shield them from scanners, just do not be in too much haste to put then in your trouser pocket in the morning Big Cry 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #667332 27th Nov 2017 7:06pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Not wishing to detract from the gravity of the original point of this thread, but I really just don't get the point of all this keyless entry thing, it seems to me to be yet another example of a solution looking for a problem that doesn't exist and then creating more security problems in the process.
How hard can it be to simply press a keyfob button when next to the car, or even shove the key in a hole and turn it, is all the extra technology really justified?
Post #667358 27th Nov 2017 7:59pm
grafty99
'Convinence' I think you'll find. Because pressing a button AND pulling the handle to open the door is just far too troublesome. Who would want to be bothered with that?! Laughing
But yes I think it's a combination of manufacturers making solutions to 'problems' that don't exist and also consumers demanding it. If there was no demand then surely they wouldn't do it? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #667364 27th Nov 2017 8:11pm
grafty99
On our campsite we have to jump start people all the time because the car is 'ready' to drive all the time because it can detect the keys through the caravan walls or indeed tent. Generally they are unlocked as well as the key is within range Rolling Eyes 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #667365 27th Nov 2017 8:13pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
From what I can guess they are using something like a HackRF and running Wireshark. Listening to the signals sent and received at both ends and just transmitting them. Much like how a wifi repeater does.
Not really complicated if you have time to work it out.
Post #667376 27th Nov 2017 8:47pm
Unlikely, since the protocols are different. Technically it's easy enough to do, but it is only recently that the technology has become small enough to be battety powered and cheap. A Chinese firm has now demonstrated phone-sized devices that will work up to 320m and cost under $20. Shocked
If you're interested, look for research by Boris Danev. If you have a car with PKE, keep the all the keys in tins at all times when you're not actually driving the car (including times like paying for fuel, etc).
PKE systems really are pointless, and, when the appalling vulnerabilities and troublesome countermeasures are considered, are more hassle and less secure than RKE systems like those on late Defenders. Provided that you make sure that the vehicle really has locked when you press the button (to defeat the simplest vulnerability of these systems), RKE systems are not easy to open.
For the technically minded, see http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.723.6172
Post #667392 27th Nov 2017 10:09pm
Procta
this is what happens when things get more technical. I saw a documentary about it all years ago. Was shocking on what tech the thieves have! Once stolen, they can just deactivate the tracker with some tricky software from a laptop. Then the car is packed up and sent out of the country.
Seen them use a fob jammer too, for central locking on older cars. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #667445 28th Nov 2017 7:14am
