![]() | Home > Puma (Tdci) > Puma Reversing Light Not Working!!! |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
Not got the diagrams with me, as I'm at work, but I'd have a look at the wiring diagram and see if there's anything else on that same circuit.
If nothing else is having issues, a complete guess would be dodgy reverse switch on the gearbox. |
HK07 Member Since: 15 Dec 2016 Location: Hampshire Posts: 755 ![]() ![]() ![]() |
Thanks BenB8man
Yes that was my first thought, but why does it show 7.8 volts? If the switch is knackered surely it would be dead. 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
Your guess is probably as good as mine!
![]() If you take off your cubby and bottom plate you should be able to access it fairly easily. If you switch to ohms and click in into reverse and back you will be able to work out what the switch is doing. Might just be high resistance through the switch which drags the voltage down. If you�re no further forward by the time I get back from work I�ll have a look through the wiring diagrams and see where it�s fed from and if anything else could affect it. That�s if no one beats me to it ![]() |
Many thanks 2007 90 Puma - Love it - Best car I have ever owned.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
This. ^^^^ You might also find like I have before that an LED will work but not a standard incandescent bulb. It will likely be the reverse switch. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
Had this on a friend's 90, new switch sorted it.
Roverrobbie Member Since: 06 Feb 2016 Location: Orkney Posts: 17 ![]() ![]() |
Had this problem . The switch contact had a high resistance . Replaced it from underneath using a 22 mm spanner. A bit tight for space but not too difficult.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4296 ![]() ![]() ![]() |
Me to. Was showing voltage at the light, but not illuminating. New switch fixed it. 2007 110 TDCi Station Wagon XS
You can do it from underneath can you?
If you do it from inside what is it; cubby box out, seats out, carpet out, then some sort of cover off to expose the gearbox? Is that about right? Once again - thanks for the advice. HK07 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
Had to do mine recently, similar symptoms.
Apparently you can do it from underneath, I personally took the cubby box out, took the access panel out and did it from the top. Get a 22mm open ended spanner to make like easier, shorter the better. My 90 Project : http://www.defender2.net/forum/topic52774.html |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Take the gear sticks out and take the gearbox tunnel cover off, that gives you the best access. It's not difficult to remove the cover. The switch on a puma is quite a way forward compared to earlier models, just forward of the gear sticks.
Might be possible from underneath, but will be exceedingly awkward i think, and burried amongst pipes and cables. |
Same here, new switch Solved! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
With my Mot looming i finally got round to buying the new switch.
Got all ready to start the job when I realised it's working again! How can this be? Should I replace it anyway? 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
Mine was intermittent- i’d suggest replacing it anyway. My 90 Project : http://www.defender2.net/forum/topic52774.html
