Home > In Car Electronics > Alpine head unit recommendation
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
Anyone got either of the below head units? Need to combine with the dab aeriel too so recommendations would be very welcome!
Thank you!
https://www.caraudiocentre.co.uk/search.as...ageItem=12
https://www.caraudiocentre.co.uk/product_m...-32981.htm
https://www.caraudiocentre.co.uk/product_m...-40394.htm
Post #666619 24th Nov 2017 10:58am
JeremyJ
I’ve got the CDE196DAB - nice unit, works well. I’m happy with it!
Post #666621 24th Nov 2017 11:01am
churchy
Thanks Jeremy - did you connect to existing aeriel (metal one on wing) or add another? Bit of a novice at this!
Post #666623 24th Nov 2017 11:13am
rustandoil
I have an Alpine UTE-930AB head unit works well, I like it, its fed from an aerial splitter like this...
http://www.caraudiodirect.co.uk/dab/autole...l-splitter
I had an adhesive aerial on the windscreen for a little while, nowhere near a good
Post #666652 24th Nov 2017 1:17pm
churchy
Thanks all - I need cd capability so the cde looks like the choice - do you guys know if the aeriel splitter would work ok with this unit to?
Post #669824 9th Dec 2017 9:54am
rustandoil
I dont see why not Thumbs Up
Post #669827 9th Dec 2017 10:12am
barbel jim
From reading others post it appears to. It might be worth replacing the currant aerial for a new one at the same time, as Bob did it on an older aerial without success, but after replacing the old aerial it worked Shocked Not something I've tried. I currently run mine with this - http://www.halfords.com/technology/car-aud...ab-antenna .
I tried the screen mount with little success, being a sunday and desperate whilst all the dash was in bits I rolled the dice, with the view Id get a roof mount one later. It works a treat Mr. Green I have it mounted above the rear door, bent at 90 degrees. A metal plate gaffer taped behind the headlining is enough to hold it. Perfect reception 99% of the time and no height restrictions.
Bobs thread -http://www.defender2.net/forum/topic31762.html?highlight=dab+splitter
Post #669828 9th Dec 2017 10:14am
Hendrix
England 2013 Defender 110 Puma 2.2 USW Santorini Black
Got the UTE93DAB works well. All my music is put onto a memory stick to save storage and any dust problems. Have got a roof mount aerial with magnetic base (as above from Halfords), attached a small piece of steel to my roof rack to give it somewhere to stick to.
Post #669839 9th Dec 2017 11:51am
