![]() | Home > In Car Electronics > Alpine head unit recommendation |
churchy Member Since: 28 Jul 2011 Location: UK Posts: 237 ![]() ![]() |
Anyone got either of the below head units? Need to combine with the dab aeriel too so recommendations would be very welcome!
Thank you! https://www.caraudiocentre.co.uk/search.as...ageItem=12 https://www.caraudiocentre.co.uk/product_m...-32981.htm https://www.caraudiocentre.co.uk/product_m...-40394.htm |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
I’ve got the CDE196DAB - nice unit, works well. I’m happy with it!
Thanks Jeremy - did you connect to existing aeriel (metal one on wing) or add another? Bit of a novice at this!
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 868 ![]() ![]() ![]() |
I have an Alpine UTE-930AB head unit works well, I like it, its fed from an aerial splitter like this...
http://www.caraudiodirect.co.uk/dab/autole...l-splitter I had an adhesive aerial on the windscreen for a little while, nowhere near a good |
I dont see why not
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1453 ![]() ![]() ![]() |
From reading others post it appears to. It might be worth replacing the currant aerial for a new one at the same time, as Bob did it on an older aerial without success, but after replacing the old aerial it worked
![]() I tried the screen mount with little success, being a sunday and desperate whilst all the dash was in bits I rolled the dice, with the view Id get a roof mount one later. It works a treat ![]() Bobs thread -http://www.defender2.net/forum/topic31762.html?highlight=dab+splitter |
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 106 ![]() ![]() ![]() |
Got the UTE93DAB works well. All my music is put onto a memory stick to save storage and any dust problems. Have got a roof mount aerial with magnetic base (as above from Halfords), attached a small piece of steel to my roof rack to give it somewhere to stick to.
