Home > Td5 > Wet carpets
excossack
Wet carpets
Having fixed the leak from the top corner of the windscreen/top of the door frame I thought great..No more front leaks and wet carpet...How wrong was I!
This time is the insulation and the floor thats wet. On closer inspection the water appears to be coming from behind the door panel. So will be removing this and having a look.
From memory there is a plastic sheet behind the panel, what is the correct setup for this? Pictures more than welcome! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #169680 21st Sep 2012 1:06pm
Killer90
Site Sponsor
the plastic sheet is there so when water does get in it runs down the sheet and not over all the mechanical bits inside the door, peel the sheet off carefully and it want tear, then stick it back on its held with dum dum- like black goo. check the foam seal where the windowscreen fixes on the bulkhead and also pull the door seal off and make sure its all nice and sealed behind there Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #169724 21st Sep 2012 5:19pm
excossack
Cheers K90. I take it then, the plastic sheets fits on the inside of the door frame rather than the outside?
I have dum-dum and some Sikaflex 290i 1999 Defender TD5 110
Regards
John M0VAZ
Post #169746 21st Sep 2012 6:49pm
Killer90
Site Sponsor
Thumbs Up once the door card is off this is what it will look like Very Happy this is a puma door so the sheet is now more like foam on the td5's they have a clear type sheet but fits exactly the same CSK Automotive
Post #169749 21st Sep 2012 6:55pm
bob neville
John
When you take the door card off you will see the membrane between the card and frame.
I had the same problem on the Puma and the TD5, water from the bottom of the door card, and both had the same problem. The seal between the window and door (waist seal) was letting water in and it managed to get the wrong side of the membrane and drip from the card.
Puma was done by LR and I purchased new waist seals and fitted them on the TD5.
There is also a gap at the front and rear of the waist seal where it meets the door/frame. Dum Dum fixed that Thumbs Up
Killer beat me to it !
2013 Defender 90 CSW - sold
Post #169751 21st Sep 2012 6:56pm
Killer90
Site Sponsor
Thumbs Up as Bob said the gaps are a pain in my case clear silicone solved this Very Happy CSK Automotive
Post #169755 21st Sep 2012 7:24pm
excossack
Cheers chaps. A few things to check out over the weekend including waist seals! Time to google them 1999 Defender TD5 110
Regards
John M0VAZ
Post #169762 21st Sep 2012 7:52pm
bob neville
ALR5980.
Dan at Duckworths supplied mine Thumbs Up
Post #169765 21st Sep 2012 8:02pm
excossack
Cheers Bob. 1999 Defender TD5 110
Regards
John M0VAZ
Post #169782 21st Sep 2012 8:31pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Does anybody know where I can get the foam membrane from? I've stripped my rear doors to replace a wiring harness but have had to sacrifice the foam in too many places.
I'd ideally like to replace it. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #666221 22nd Nov 2017 2:33pm
Martin
Site Admin
EJD500400 Rear RH
EJD500410 Rear LH  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #666223 22nd Nov 2017 2:46pm
Djcla
@excossack what sort of luxury/high end Defender do you have that has Carpets?
Post #666296 22nd Nov 2017 8:04pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
^^^^ Seriousy^^^^. I ditched my carpeting for rubber mats all round. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #666374 23rd Nov 2017 12:58am
Djcla
Yeah agree , carpets get trashed In our cars... Im going to invest in some genuine rubber mats when I can too.
Post #666387 23rd Nov 2017 8:49am
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
2 pics from the inside of a 2003 before I peeled the plastic off to repair the door bottoms. I replaced the plastic with builders plastic sheet from screwfix.
Post #666509 23rd Nov 2017 9:34pm
