![]() | Home > Td5 > Wet carpets |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
the plastic sheet is there so when water does get in it runs down the sheet and not over all the mechanical bits inside the door, peel the sheet off carefully and it want tear, then stick it back on its held with dum dum- like black goo. check the foam seal where the windowscreen fixes on the bulkhead and also pull the door seal off and make sure its all nice and sealed behind there
![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5951 ![]() ![]() ![]() |
Cheers K90. I take it then, the plastic sheets fits on the inside of the door frame rather than the outside?
I have dum-dum and some Sikaflex 290i 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
John
When you take the door card off you will see the membrane between the card and frame. I had the same problem on the Puma and the TD5, water from the bottom of the door card, and both had the same problem. The seal between the window and door (waist seal) was letting water in and it managed to get the wrong side of the membrane and drip from the card. Puma was done by LR and I purchased new waist seals and fitted them on the TD5. There is also a gap at the front and rear of the waist seal where it meets the door/frame. Dum Dum fixed that ![]() Killer beat me to it ! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Cheers chaps. A few things to check out over the weekend including waist seals! Time to google them 1999 Defender TD5 110
ALR5980.
Dan at Duckworths supplied mine ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Cheers Bob. 1999 Defender TD5 110
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Does anybody know where I can get the foam membrane from? I've stripped my rear doors to replace a wiring harness but have had to sacrifice the foam in too many places.
I'd ideally like to replace it. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6664 ![]() ![]() ![]() |
EJD500400 Rear RH
EJD500410 Rear LH ![]() ![]() |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
@excossack what sort of luxury/high end Defender do you have that has Carpets?
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 970 ![]() ![]() ![]() |
^^^^ Seriousy^^^^. I ditched my carpeting for rubber mats all round. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Yeah agree , carpets get trashed In our cars... Im going to invest in some genuine rubber mats when I can too.
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
2 pics from the inside of a 2003 before I peeled the plastic off to repair the door bottoms. I replaced the plastic with builders plastic sheet from screwfix.
![]() Click image to enlarge ![]() Click image to enlarge |
