![]() | Home > Puma (Tdci) > Water Ingress Sheet |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
they can leak via the hinge gasket 2.4 90 XS
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Mine leaks in the rear footwell, someone can't drill holes at the factory and it gets in through the oval hole!
Maybe with the cash us Taxpayers are giving LR they could teach their employees a few skills. |
dm,do you mean poor fitting door seal ?,I was told awhile back that a door seal from a series LR is a better fit, or you could try packing the seal were it fits to body with bluetack or bodycorking. 2.4 90 XS
Both mine leaked.
back to dealer changed both. on inspection they have put silicon on them to hold both them in seems to work no more leaks. but for how long, who knows. ![]() |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Some things never change. Is nice to see that almost all of us had a water ingress problems in one or another part of ourPumas.
I had some water ingress in the passenger side and has been repaired at the end of the winter (rainy season here). So I will see in May-June if really works. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Yes the door seal is poor fitting (loose) across the top of the door. It's a press fit, so I'm going to first try squeezing the seal's sides together and see if that fixes it. If not I'll talk to the dealer and see what they recommend (maybe sikaflex it on). Can't get to a dealer (nearest is 1100km) at present as the track out of town will be impassable for the next few months. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
