Home > Puma (Tdci) > Water Ingress Sheet
Page 2 of 2 <12
Grockle
I would check windscreen seal first,on our TD5 their was was a pressing fault and water got in where the seal wasn't tight. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #6625 27th Jan 2009 12:58pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Door seal near the mirror is my first thought as it seems to accumulate from that side of the foot well. If it is the windscreen seal its running down from the very outer edge. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #6626 27th Jan 2009 1:35pm
Grockle
they can leak via the hinge gasket 2.4 90 XS
Post #6627 27th Jan 2009 1:59pm
dm_td5
Found it! It's amazing how easy it is to find a water leak when its raining about 2" in 10 minutes. Was sitting in the car waiting out the worst of it and found it's coming through the rather loosened top door seal. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #6643 28th Jan 2009 12:14pm
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Mine leaks in the rear footwell, someone can't drill holes at the factory and it gets in through the oval hole!
Maybe with the cash us Taxpayers are giving LR they could teach their employees a few skills.
Post #6644 28th Jan 2009 1:19pm
Grockle
dm,do you mean poor fitting door seal ?,I was told awhile back that a door seal from a series LR is a better fit, or you could try packing the seal were it fits to body with bluetack or bodycorking. 2.4 90 XS
Post #6645 28th Jan 2009 1:26pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Both mine leaked.
back to dealer changed both.
on inspection they have put silicon on them to hold
both them in seems to work no more leaks.
but for how long, who knows. Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #6653 28th Jan 2009 3:01pm
Eduardo
Some things never change. Is nice to see that almost all of us had a water ingress problems in one or another part of ourPumas.
I had some water ingress in the passenger side and has been repaired at the end of the winter (rainy season here). So I will see in May-June if really works.
Cheers Eduardo
Post #6655 28th Jan 2009 3:09pm
dm_td5
Yes the door seal is poor fitting (loose) across the top of the door. It's a press fit, so I'm going to first try squeezing the seal's sides together and see if that fixes it. If not I'll talk to the dealer and see what they recommend (maybe sikaflex it on). Can't get to a dealer (nearest is 1100km) at present as the track out of town will be impassable for the next few months. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #6660 28th Jan 2009 10:15pm
Page 2 of 2 <12
