![]() | Home > Maintenance & Modifications > Intermittent Front Wiper- variable delay |
| I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404
Here's an easy one for you, relatively cheap and one you'll use almost every day (especially in Scotland
Replace the standard wiper relay with a VW Relay 99. The default interval is, say 10 seconds. to get a different length of time, you put the switch to intermittent then back to the 'off position before the wipers return to park position. You then put the switch to intermittent after the appropriate interval. IE "On,off...15 seconds...on" gives you a 15 sec interval or "on,off..4 secs..on" gives 4 second interval. It also governs how many wipes of the front windscreen you get when you use the washer jets, 1 wipe for a small squirt, more for a longer press of the washer switch. Fitting is really easy. On a Td5 or Tdi, remove the instrument cluster (4 screws) and remove the LR (lucas) relay. I ascertained which relay it was by activating the intermittent wipers and listening/feeling the relay 'click', once removed simply plug in the VW '99' relay, and obviously check the wipers still work on intermittent before you put it back together. Click image to enlarge the relay fitted in my Td5 (02MY, non A/C) For the TDCi, open the fuse box under the steering wheel, either a screwdriver or a thin coin does the trick. On a 110 XS USW the pinky/red lucas relay was in the top middle position: Click image to enlarge Fitted easily: Click image to enlarge EDIT- Adding TDCi photos, new photo hosting replacing original broken links. Mark S CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum Last edited by I.AM_a driver on 7th Sep 2015 9:12pm. Edited 1 time in total |
| CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140
Andy, the relay is available second-hand on ebay for few quids (i paid mine 7.5 GBP +P&P) to work, the wiper stalk has to be in the intermittent position otherwise the current is cut and noting works To stop the intermittent wiping, just put on off position. |
Works on the Puma too (see Dgardel's thread). Just the relay is in a different location (relay box under the steering wheel) |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
Thanks for that.
Will have a look at the Bay, and get one ordered, so I can use it whilst not in my work uniform Andy |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
http://www.defender2.net/forum/topic1810.h...able+delay Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
I found mine on eBay too, just under £10 inc postage, pretty cheap as they seem to go for up to £20 (I used www.gixen.com to snipe for me
Yes, to clarify the wiper only works in the intermittent position (as standard), the only difference is you put switch to 'off/park' position while the wiper is moving then back to intermittent to set the delay/interval you want. (edit-adding italicised text above for clarity) Mark S CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum Last edited by I.AM_a driver on 8th Apr 2011 10:24pm. Edited 1 time in total |
Thanks for that
Andy |
| party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311
Thanks for the post......
Reminded me I'd bought a relay off ebay the last time this topic surfaced and had completely forgotten to fit it. Sorted this afternoon...... |
Fitted one to a mate's TDCi 90 after a 4x4 response meeting on Wednesday, it's so much easier on the TDCi as you don't need to take the instruments off.
Another member on here bought one of the relays from me for his TDCi 110, don't know if he's fitted it yet though. The advantages of buying a job lot of relays become clear, you can spread the word about how easy it is and how useful it is. Mark S CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
sounds like a great idea found this on another forum
Taken from Lotus Forum: Various part numbers have been put forward as replacements. Obtaining new relays is possible but the majority can be found from the local breakers yard: * Beru: 0 900 301 082 * Kostal: 377 955 531 * Bosch: 0 986 335 058 * VW: 3B0955531 ................. has 197 printed on the top, info from Audi/VW dealer - superseded by VW 357 955 531 (type 99 below) * www.gsfcarparts.com pt no 93610 * OPEL 12 38 550 * SAAB 85 53 463 * VW 191 955 531 ................. believed to be the standard type 19 relay * VW 357 955 531 ................. the type 99 relay * VW 321 955 531 A ............... (sourced one from theairflowmetercompany on ebay and it didnt do anything different, had no VW logo, just part number and circuit diagram printed on it, possibly a duff clone) * LIEBHERR 1 001 443 3 * JOHN DEERE AZ 49 989 * HAKO 90-35730-2 * KRAMER 100 010 51 46 * HYMER 0416073 * Hella 5WG 003 620-021 * Use these part numbers at your own risk! * Some certainly aren't quite the correct relays, some are!! DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Just had a second hand relay delivered off e/bay cost £9.50 + postage fitted it to my 2011 XS in about 20seconds flat works perfectly, will now get a new one to fit, great mod well worth the money DEFENDER 90 TDCI XS,
| iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343
Just done mine from an eBay purchase, thanks robertjameswattsrob
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
If the second hand one works ok, why get another new one? John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
| Kez Member Since: 11 Apr 2011 Location: UK Posts: 271
Just found six left for sale left at £4.99 including delivery ! eBay item number: eBay Item No. 150518624443
| All times are GMT |
