![]() | Home > Maintenance & Modifications > Clutch fluid. |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 ![]() ![]() ![]() |
Changed my DOT4 clutch fluid today and it resembled black ink. 10 minute job.
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306 ![]() ![]() ![]() |
How long had it been in there?
Maybe 5 years....👍
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
It turns black quite quickly, worth changing though.
Pitch black. Going to do it annually now.
I change mine when I do the brake fluid, so every 2 years
I only changed the reservoir. Is there a bleed nipple on a Puma?
Better change mine soon, it�s been fermenting for over 15 years since I last changed the slave cylinder..
If you have a good grip you don't need a spanner to release the bleed nipple. I just put my hand up and I can open and shut it that way. Safer in my opinion
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
How do you do it?
Any write up or pics would be great. Mine is a td5 so will it be the same? |
