Home > Technical > Dixon bate drop plate
mse
Im sure a while back i saw something about someone securing their drop plate eg making it difficult to remove the pins...anyone remember anything. Mike
Post #663989 13th Nov 2017 7:02pm
There was somebody who'd bolted their slider to the frame. Is that what you mean? Darren
Post #663993 13th Nov 2017 7:05pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I'm sure I have seen somewhere a trick where you drill the spring clip holes out and fit small padlocks with long shackles. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #663994 13th Nov 2017 7:06pm
barbel jim
Both have been done Thumbs Up The padlocks can suffer though from the salt Big Cry I used to just leave mine in the back, which I got fed up with so reverted back to a fixed one now, and less rattling.
Post #663996 13th Nov 2017 7:11pm
mse
THanks
It wasnt bolted it was some sort of lock - changed pin
i think i have started to find it:
https://www.maypole.ltd.uk/mp4832-dixon-ba...s-db202018
[/url] Mike
Post #664000 13th Nov 2017 7:21pm
barbel jim
That'll work, Just pack it well with grease when you put it on
Post #664002 13th Nov 2017 7:24pm
Cupboard
Has anyone actually had their slider nicked?
I've got plenty of additional security on my Defender but nothing on the tow hitch!
Post #664070 13th Nov 2017 10:05pm
I used to use one of the genuine DB locking pins and it was (a) expensive for what it was and (b) utterly useless! Stuck behind a Defender it is a magnet for road crud, salt, and who knows what, and even though I used to bind it with insulating tape whenever I used it, within about 6 weeks it had become unusable.
I then binned the lock part, and tapped a suitable thread on the end of the pin so I could fit a decent quality keyed locking wheel nut to the end of the pin. That lasted ok, but was a hassle, so I stopped using it.
I now keep the slider(s) safely inside the vehicle and only fit them when needed (in fact since I went over to using a 2" receiver coupling, I keep the whole caboodle inside the vehicle when not in use. When in use I fit a padlock and chain when necessary).
Post #664101 13th Nov 2017 11:32pm
mse
It's not to stop it being stolen, it's to stop the trailer being stolen, when it's on, its hitch is locked but that's pointless if you can just pull the pins out Thumbs Up Mike
Post #664883 16th Nov 2017 8:57pm
I wouldn't rely on the DB lock to stop my trailer being nicked, that's what the padlock and chain is for!
However every little helps, it would be better than nothing.
Post #664885 16th Nov 2017 9:04pm
mse
Not when you say stop at a services etc or pull in to pick something up. The hitch lock will stop it being detached easily but it's pointless on a sliding detachable hitch. Thumbs Up
When it's not on the car it's got security Mike
Post #664898 16th Nov 2017 9:18pm
I agree, that's what the padlock and chain is for. The DB lock I found to be too fiddly, unreliable, and ultimately too weak (eventually when it finally died and wouldn't unlock I removed it using brute force and it toom seconds only).
Post #664966 17th Nov 2017 12:16am
barbel jim
Another reason I reverted back to fixed Mr. Green
Post #665009 17th Nov 2017 9:30am
mse
Cant have a fixed set up with the NAS tow step im afraid otherwise i would Mike
Post #665756 20th Nov 2017 3:31pm
X4SKP
I have both a Fixed and 'Non-Fixed' Slider on my DB Drop Plate...All off the back of a NAS Rear Step...
Fixed
The Lower Slider has an ALKO Extended Reach 50mm Dia Ball Tow Hitch. The Upper Bolts go through the Slider, Drop Plate and link to the 'Bracing Metalwork' leading back to the Chassie. This arrangement 'secures' the Slider (to a degree) Strengthens the forces at work with the Drop Plate, and prevents any 'rattle' of the Slider on the Drop Plate.
The Padlock on the retention Pins would be a effective as those used on Storage Hunters, and I have replaced this now with a simple thick cable pull, again adding nothing really as the two Pins are 'locked' and don't easily rotate, or be withdrawn through the Slider.
Non-Fixed
The Top Slider has the NATO Hitch and is generally not left on the vehicle, just put into service occasionally, the NATO Hitch is generally around £150-200 second hand, (this one was £30 at an MOD Auction) but I would still not like to loose it, but for the way I use this Hitch, with an open Trailer (Rapier) I would not leave this unattended, so the easily removable set up I have I don't view as a problem.
The Fixed Set Up is more important to Secure as it tows our Caravan and even when away and not Towing, if someone revealed me of my Slider and Tow Ball it would be both inconvenient (i.e Censored) and a hassle to sort out that I'd rather not have.
Good Luck SKIP
Post #665760 20th Nov 2017 4:03pm
