![]() | Home > Maintenance & Modifications > Discovery 200tdi in a Defender Power Steer bottom pipe leak |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I had the same problem on my Disco 1 , it was in the garage for 2 days while they stripped bits off to remove the pipe and refit a new one.
This is a pressure fitting a jubilee clip will not hold the pressure. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
Thanks for that, looks like it’s the low pressure side so think I may be alright to cut off the p clip and resecure.
Quick update, all sorted, jubilee clip did the trick, leak was on the return circuit not the high pressure hose. Done a search but not really conclusive what PS fluid to use, think it has ATF in originally however will normal PS fluid do.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8402 ![]() ![]() ![]() |
on the LP side you can use jubilee clips, std on attachment to the res. Cheers
