Home > Maintenance & Modifications > Discovery 200tdi in a Defender Power Steer bottom pipe leak
dioliahary
Hi mine has started to leak from where the rubber meets the metal pipe and the OEM clamp secure it together part number NTC 2595 I think.
Has anyone ever cut the OEM clamp off and replaced it with a jubilee clip.
Rather than renew the complete hose from PS unit to reservoir.
Post #662650 8th Nov 2017 3:12pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I had the same problem on my Disco 1 , it was in the garage for 2 days while they stripped bits off to remove the pipe and refit a new one.
This is a pressure fitting a jubilee clip will not hold the pressure. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #662655 8th Nov 2017 4:12pm
dioliahary
Thanks for that, looks like it’s the low pressure side so think I may be alright to cut off the p clip and resecure.
Post #662671 8th Nov 2017 6:19pm
dioliahary
Quick update, all sorted, jubilee clip did the trick, leak was on the return circuit not the high pressure hose. Done a search but not really conclusive what PS fluid to use, think it has ATF in originally however will normal PS fluid do.
Post #663195 10th Nov 2017 7:27pm
jst
on the LP side you can use jubilee clips, std on attachment to the res. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #663365 11th Nov 2017 9:52am
