Home > Maintenance & Modifications > Naka raised air intake
familymad
Now the turbo pipe has ruptured on the 130 I'd might as well sort the intakeside of things while doing the intercooler. Lots of current chat about Nugget Stuff intakes and airbox mods.
Naka do an intake which claims to straighten the air intake out. Has anyone fitted it and can show what it does from wing top onwards? I assume you can seal this in a similar way to the Nugget stuff gear to improve water resistance?
Reason I ask is adding the Nugget intake plus RAI you come out with a broadly similar price.
Other option is Nugget stuff and say a Safari bolt on jobbie 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #662016 5th Nov 2017 6:36pm
camelman
Are you just looking for a sealed snorkel?
The Southdown one is around £170 and fully sealed thru to the airbox. http://www.southdown4x4.co.uk/Snorkel%20Defender%20Puma%
Post #662026 5th Nov 2017 7:29pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
http://www.southdown4x4.co.uk/Snorkel%20De...norkel.htm Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #662099 5th Nov 2017 11:05pm
I have a Nakatanenga system fitted and (in my opinion) it is in a different league to anything else. It also made a surprising difference to engine performance.
There is a large bore flexi pipe from the wing top to the air box very similar to a Nugget duct but IIRC larger. I will try to get a picture or two tomorrow.
There is a thread on here with pictures already, somewhere, if you search.
Post #662116 5th Nov 2017 11:56pm
bankz5152
Fit the Southdown, replaces the terrible restrictive LR intake with a solid 3" pipe straight to the air box.
Post #662172 6th Nov 2017 11:56am
familymad
Is the wing cut to receive the SD one? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #662273 6th Nov 2017 8:25pm
I think the Nak pipes's bigger than the SD.
Post #662278 6th Nov 2017 9:05pm
These two threads have information and pictures of the Nakatanenga RAI, including the bits under the bonnet.
http://www.defender2.net/forum/topic53507.html
http://www.defender2.net/forum/topic41867.html
Post #662349 7th Nov 2017 9:50am
